Cannot rename any directory inside cryptometer vault on mac [solved]
tl;dr: to solve problem: close cryptometer; re-install homebrew and fuse-t, restart computer.
Edit: Naturally I figured this out approximately 5 seconds after submitting the help request. Left here for anyone else having the same issue.
Original issue description
Hi, since upgrading to MacOS 15.4 I can no longer rename any directory inside my cryptometer vault. I have two vaults, one stored on OneDrive, another on iCloud. Renaming fails in both. The “rename” menu option is greyed out. Pressing “enter” in finder to rename has no effect. New folders cannot be changed from “untitled folder” to anything else. Looking at the properties of the directories, none of them are “locked” and I have read-write permissions.
Nothing else seems wrong. I can rename any other filetype. I can create and delete directories. Copying and moving files seems fine.
I am using Cryptometer version 1.15.1 with FUSE-T.
Things that have no effect:
  • restarting the computer
  • closing onedrive
  • restarting onedrive
  • lock and unlocking vaults
  • closing and re-opening cryptometer
  • re-installing FUSE-T (latest version as of Apr 13, 2025)
