Trying to open an existing vault on pCloud and it throws an error
Error Code 6PHE:UAN1:UAN1
org.cryptomator.cryptofs.VaultConfigLoadException: Failed to parse config:
at org.cryptomator.cryptofs@2.1.1/org.cryptomator.cryptofs.VaultConfig.decode(VaultConfig.java:115)
at org.cryptomator.desktop@1.6.3/org.cryptomator.common.vaults.VaultConfigCache.readConfigFromStorage(VaultConfigCache.java:62)
at org.cryptomator.desktop@1.6.3/org.cryptomator.common.vaults.VaultConfigCache.reloadConfig(VaultConfigCache.java:30)
at org.cryptomator.desktop@1.6.3/org.cryptomator.common.vaults.VaultListManager.create(VaultListManager.java:102)
at org.cryptomator.desktop@1.6.3/org.cryptomator.common.vaults.VaultListManager.lambda$add$0(VaultListManager.java:65)
at java.base/java.util.Optional.orElseGet(Unknown Source)
at org.cryptomator.desktop@1.6.3/org.cryptomator.common.vaults.VaultListManager.add(VaultListManager.java:64)
at org.cryptomator.desktop@1.6.3/org.cryptomator.ui.addvaultwizard.ChooseExistingVaultController.chooseFileAndNext(ChooseExistingVaultController.java:80)
at com.sun.javafx.reflect.Trampoline.invoke(MethodUtil.java:77)
at jdk.internal.reflect.GeneratedMethodAccessor2.invoke(Unknown Source)
at javafx.base/com.sun.javafx.reflect.MethodUtil.invoke(MethodUtil.java:275)
at javafx.fxml/com.sun.javafx.fxml.MethodHelper.invoke(MethodHelper.java:84)
at javafx.fxml/javafx.fxml.FXMLLoader$MethodHandler.invoke(FXMLLoader.java:1854)
at javafx.fxml/javafx.fxml.FXMLLoader$ControllerMethodEventHandler.handle(FXMLLoader.java:1724)
at javafx.base/com.sun.javafx.event.CompositeEventHandler.dispatchBubblingEvent(CompositeEventHandler.java:86)
at javafx.base/com.sun.javafx.event.EventHandlerManager.dispatchBubblingEvent(EventHandlerManager.java:234)
at javafx.base/com.sun.javafx.event.EventHandlerManager.dispatchBubblingEvent(EventHandlerManager.java:191)
at javafx.base/com.sun.javafx.event.CompositeEventDispatcher.dispatchBubblingEvent(CompositeEventDispatcher.java:59)
at javafx.base/com.sun.javafx.event.BasicEventDispatcher.dispatchEvent(BasicEventDispatcher.java:58)
at javafx.base/com.sun.javafx.event.EventDispatchChainImpl.dispatchEvent(EventDispatchChainImpl.java:114)
at javafx.base/com.sun.javafx.event.BasicEventDispatcher.dispatchEvent(BasicEventDispatcher.java:56)
at javafx.base/com.sun.javafx.event.EventUtil.fireEventImpl(EventUtil.java:74)
at javafx.base/com.sun.javafx.event.EventUtil.fireEvent(EventUtil.java:49)
at javafx.base/javafx.event.Event.fireEvent(Event.java:198)
at javafx.graphics/javafx.scene.Node.fireEvent(Node.java:8792)
at javafx.controls/javafx.scene.control.Button.fire(Button.java:203)
at javafx.controls/com.sun.javafx.scene.control.behavior.ButtonBehavior.mouseReleased(ButtonBehavior.java:208)
at javafx.controls/com.sun.javafx.scene.control.inputmap.InputMap.handle(InputMap.java:274)
at javafx.base/com.sun.javafx.event.CompositeEventHandler$NormalEventHandlerRecord.handleBubblingEvent(CompositeEventHandler.java:247)
at javafx.base/com.sun.javafx.event.CompositeEventHandler.dispatchBubblingEvent(CompositeEventHandler.java:80)
at javafx.base/com.sun.javafx.event.EventUtil.fireEvent(EventUtil.java:54)
at javafx.graphics/javafx.scene.Scene$MouseHandler.process(Scene.java:3897)
at javafx.graphics/javafx.scene.Scene.processMouseEvent(Scene.java:1878)
at javafx.graphics/javafx.scene.Scene$ScenePeerListener.mouseEvent(Scene.java:2623)
at javafx.graphics/com.sun.javafx.tk.quantum.GlassViewEventHandler$MouseEventNotification.run(GlassViewEventHandler.java:411)
at javafx.graphics/com.sun.javafx.tk.quantum.GlassViewEventHandler$MouseEventNotification.run(GlassViewEventHandler.java:301)
at javafx.graphics/com.sun.javafx.tk.quantum.GlassViewEventHandler.lambda$handleMouseEvent$2(GlassViewEventHandler.java:450)
at javafx.graphics/com.sun.javafx.tk.quantum.QuantumToolkit.runWithoutRenderLock(QuantumToolkit.java:424)
at javafx.graphics/com.sun.javafx.tk.quantum.GlassViewEventHandler.handleMouseEvent(GlassViewEventHandler.java:449)
at javafx.graphics/com.sun.glass.ui.View.handleMouseEvent(View.java:557)
at javafx.graphics/com.sun.glass.ui.View.notifyMouse(View.java:943)
at javafx.graphics/com.sun.glass.ui.gtk.GtkApplication._runLoop(Native Method)
at javafx.graphics/com.sun.glass.ui.gtk.GtkApplication.lambda$runLoop$11(GtkApplication.java:290)
Same issue from andorid and windows as well. I can access oneDrive through cryptomator fine.
have you looked up the error in our error database? It might be already ahswered there. If not, it would be awesome if you open a new ticket there so other users with the same error can easily find the answer.
Remark: I assume you also opened the following ticket on our bug tracker
