Similar problem here (Win 10 Pro 64 Bit german build 19043.1110) / cryptomator 1.5.16.2831.223 / dokany 1.5.3000
... 11 more
Caused by: com.dokany.java.DokanyException: DokanMain returned error code-5: Dokan mount failed - Cannot assign a drive letter or mount point. Probably already used by another volume.
at com.dokany.java.DokanyMount.lambda$mount$2(DokanyMount.java:98)
... 1 more
