I’m on 12.1 Monterey and lately I can’t lock my Vault anymore. When trying to lock it I get the error that because of “ongoing processes” the vault can’t be locked (I closed every application that used files from my vault so thats BS). When trying to force lock my vault, I get another error message and no explanation whatsoever.
This is really frustrating. Can anyone help?
This is what the log says:
13:07:51.099 [JavaFX Application Thread] ERROR o.cryptomator.ui.common.VaultService - Failed to lock vaults Vault
java.util.concurrent.ExecutionException: org.cryptomator.common.vaults.Volume$VolumeException: org.cryptomator.frontend.fuse.mount.FuseMountException: Unmount failed. STDERR: umount: unmount(/Volumes/Vault): Operation not permitted
at java.base/java.util.concurrent.FutureTask.report(Unknown Source)
at java.base/java.util.concurrent.FutureTask.get(Unknown Source)
at org.cryptomator.desktop@1.6.3/org.cryptomator.ui.common.VaultService$WaitForTasksTask.call(VaultService.java:145)
at org.cryptomator.desktop@1.6.3/org.cryptomator.ui.common.VaultService$WaitForTasksTask.call(VaultService.java:128)
at javafx.graphics/javafx.concurrent.Task$TaskCallable.call(Task.java:1426)
Caused by: org.cryptomator.common.vaults.Volume$VolumeException: org.cryptomator.frontend.fuse.mount.FuseMountException: Unmount failed. STDERR: umount: unmount(/Volumes/Vault): Operation not permitted
at org.cryptomator.desktop@1.6.3/org.cryptomator.common.vaults.FuseVolume.unmount(FuseVolume.java:105)
at org.cryptomator.desktop@1.6.3/org.cryptomator.common.vaults.Vault.lock(Vault.java:176)
at org.cryptomator.desktop@1.6.3/org.cryptomator.ui.common.VaultService$LockVaultTask.call(VaultService.java:180)
at org.cryptomator.desktop@1.6.3/org.cryptomator.ui.common.VaultService$LockVaultTask.call(VaultService.java:162)
... 5 common frames omitted
Caused by: org.cryptomator.frontend.fuse.mount.FuseMountException: Unmount failed. STDERR: umount: unmount(/Volumes/Vault): Operation not permitted
at org.cryptomator.frontend.fuse@1.3.3/org.cryptomator.frontend.fuse.mount.MacMounter$MacMount.assertUmountSucceeded(MacMounter.java:158)
at org.cryptomator.frontend.fuse@1.3.3/org.cryptomator.frontend.fuse.mount.MacMounter$MacMount.unmountInternal(MacMounter.java:132)
at org.cryptomator.frontend.fuse@1.3.3/org.cryptomator.frontend.fuse.mount.AbstractMount.unmount(AbstractMount.java:36)
at org.cryptomator.desktop@1.6.3/org.cryptomator.common.vaults.FuseVolume.unmount(FuseVolume.java:103)
... 8 common frames omitted
13:09:25.555 [App Scheduled Executor 02] INFO o.c.common.settings.SettingsProvider - Settings saved to /Users/blabla/Library/Application Support/Cryptomator/settings.json
13:12:28.545 [JavaFX Application Thread] WARN org.cryptomator.ui.lock.LockWorkflow - Lock of Vault failed.
at org.cryptomator.desktop@1.6.3/org.cryptomator.common.vaults.FuseVolume.unmountForced(FuseVolume.java:95)
at org.cryptomator.desktop@1.6.3/org.cryptomator.common.vaults.Vault.lock(Vault.java:174)
at org.cryptomator.desktop@1.6.3/org.cryptomator.ui.lock.LockWorkflow.call(LockWorkflow.java:60)
at org.cryptomator.desktop@1.6.3/org.cryptomator.ui.lock.LockWorkflow.call(LockWorkflow.java:31)
at org.cryptomator.frontend.fuse@1.3.3/org.cryptomator.frontend.fuse.mount.MacMounter$MacMount.unmountForcedInternal(MacMounter.java:144)
at org.cryptomator.frontend.fuse@1.3.3/org.cryptomator.frontend.fuse.mount.AbstractMount.unmountForced(AbstractMount.java:41)
at org.cryptomator.desktop@1.6.3/org.cryptomator.common.vaults.FuseVolume.unmountForced(FuseVolume.java:93)
... 10 common frames omitted
