Can not select Dropbox for usage in a new vault
i want to create a new vault on Dropbox. But I can not select Dropbox:
Can anybody help?
Thanks g.g.
Seems you did not install Dropbox with standard paths. So it can’t be detected by Cryptomator.
Please use „custom location“ and select a folder that is included in your Dropbox sync.
See documentation here: Adding Vaults — Cryptomator 1.6.0 documentation
And forum post here: How is default location for cloud services detected?
Thanks a lot. Yes, you are right. I don’t use the standard path for my dropbox directory. I understand the pre-selection on new vault is just a selection of a simple directory.
