Can I zip encrypted vault?
Can I zip encrypted vault? I mean not unlocked.
Exactly locked local one. Just archive it and upload backup to cloud that do not support Cryptomator (like Mega)
Won’t it get corrupted?
I plan to just download it after I need it, unarchive and add to Cryptomator. And vice versa.
Yes. In the end, a vault is just a folder. with a bunch of subfolders of files. As long as you don’t edit this folder manually, everything 's good.
could you explain how mega doesn’t support cryptomator because i upload to mega using there is app .. is there something that i should be worry of
Mega is supported on desktops like any other storage with a sync, as Cryptomator desktop does only create local files and does not connect directly to a cloud storage.
Mega is not supported on mobile devices, as Cryptomator mobile does connect directly to a cloud storage, and thus this connection must be supported. which is not the case for mega.
