Hi everyone, I used Cryptomator without problems until I installed FUSE. After installing FUSE Cryptomator mounts safes with strange names, before fuse the safe was mounted with the same name as the safe, after fuse the safe is mounted with a strange name “G6NFcnRA2US2”. I tried reinstalling Cryptomator but to no avail. Do you have any ideas?
Welcome to the Cryptomator Community,
if you use macFUSE or FUSE-T, on macOS the mountpoint directory must be unique and only the volume display name is set the the vault name.
With the fuse volume types you can select an empty directory as mountpoint. Then you have your desired,fixed directory name.
