I have a problem with Cryptomator that seems to be unintended from what I’ve gathered here.
My C: drive gets filled up when using Cryptomator on a large dataset. From another topic it seems that Cryptomator should write directly to the intended data location but the C drive seems to be used temporarily.
I’ve used task manager to look at what happens while transferring data to my NAS and it seems to buffer in some way, transferring the data to the C drive first (heavy usage of drives) and then after it’s complete with a file it then sends it over the network to the NAS. While there’s heavy usage of my data drive and the C drive there is not network activity so it definitely does not operate directly on the NAS storage.
VeraCrypt can put data directly on remote storage like a NAS without using the C drive where as Cryptomator seems to use the C drive as temporary storage until it then gets send onto the final storage device like a NAS.
Can anyone clarify this? If it’s intended I hope it could be changed in the future as Cryptomator currently is unusable in scenarios with a dataset larger than the C drive.
