I updated my Mac to Big Sur. Now I get following error message when I try to open my vault.
at org.cryptomator.common.vaults.FuseVolume.mount(FuseVolume.java:107)
at org.cryptomator.common.vaults.FuseVolume.mount(FuseVolume.java:58)
at org.cryptomator.frontend.fuse.mount.MacMounter.mount(MacMounter.java:45)
at org.cryptomator.common.vaults.FuseVolume.mount(FuseVolume.java:105)
... 12 more
at org.cryptomator.frontend.fuse.mount.MacMounter.mount(MacMounter.java:43)
... 13 more
... 14 more
Please could you help me how I can resolve this problem?
Thanks
Philipp
