Automatic Backup to Cryptomator Dokany drive
Hi Folks!
Windows 10; Cryptomator 1.4.10
I’m trying to use Microsoft Backup (Built in Windows 10) to do a backup to a drive that is encrypted by Cryptomator. Then I want to copy it automatically to my cloud storage.
The problem is that Microsoft Backup can’t see the Dokany drive, the letter of the drive does not appear on the list.
Did any of you managed to find a workaround?
Can you advise any way to do it?
Or perhaps some other backup software that under Windows can work with Cryptomator/Dokany drive?
Thank you in advance for any response.
Best regards,
Xyo
Microsoft does expect a external harddrive for that and therefore does not list drives that do not identify them self as such a storage.
You can configure a network share as destination in the advanced options (at least with my WIN Pro), but you have to enable the network detection and file sharing for the destination. Just follow the steps microsoft is asking for, if you want to give this a try.
I did not do that, and therefore I cannot say if this will work then, but I do not see that this will run at least stable.
I recommend a 3rd pary software.
(What tool do you use to automatically unlock your cryptomator vault and sync the files in your vault with the local copies of those files?)
