I’m on Windows 10 Pro 1909 with Cryptomator 1.4.15 and I’m using the Dokany volume type with saved passwords, auto-unlock and custom drive letters on 3 vaults.
After boot all drives show up like in the screenshot attached and give the attached error when I try to access them.
When I lock all vaults and close Cryptomator the weird drives stay mounted. After opening Cryptomator again they get replaced by the correctly auto-mounted vaults.
Is this a know problem of the experimental auto-unlock option? Is there anything I can do to fix that?
No you don’t have to. If the (actually) latest version is installed than its ok. As far as I understood the devs, there was only a compatibility problem with the latest version that was not expected, and future updates will consider dokany driver as well.
But as you have the latest dokany installed, I unfortunately do not have a clue what is causing your problems. Does it work properly with WebDAV?
After unlocking a drive, I checked some emails, went back to cryptomator to click “reveal drive” and encountered the “Location is not available” error again
16:46:17.548 [Thread-2923] TRACE o.c.frontend.dokany.ReadWriteAdapter - (125) / opened successful with handle 125.
16:46:17.548 [Thread-2924] TRACE o.c.frontend.dokany.ReadWriteAdapter - Try to open / as Directory.
16:46:17.548 [Thread-2924] TRACE o.c.frontend.dokany.ReadWriteAdapter - (126) / opened successful with handle 126.
16:46:17.557 [Thread-2925] TRACE o.c.frontend.dokany.ReadWriteAdapter - (125) getFileInformation() is called for /.
16:46:17.558 [Thread-2925] TRACE o.c.frontend.dokany.ReadWriteAdapter - (125) Filesize of / is 4096.
16:46:17.558 [Thread-2925] TRACE o.c.frontend.dokany.ReadWriteAdapter - (125) File Information successful read from /.
16:46:17.558 [Thread-2926] TRACE o.c.frontend.dokany.ReadWriteAdapter - (126) getFileInformation() is called for /.
16:46:17.558 [Thread-2927] TRACE o.c.frontend.dokany.ReadWriteAdapter - (125) getFileInformation() is called for /.
16:46:17.558 [Thread-2926] TRACE o.c.frontend.dokany.ReadWriteAdapter - (126) Filesize of / is 4096.
16:46:17.558 [Thread-2927] TRACE o.c.frontend.dokany.ReadWriteAdapter - (125) Filesize of / is 4096.
16:46:17.558 [Thread-2926] TRACE o.c.frontend.dokany.ReadWriteAdapter - (126) File Information successful read from /.
16:46:17.558 [Thread-2927] TRACE o.c.frontend.dokany.ReadWriteAdapter - (125) File Information successful read from /.
16:46:17.581 [Thread-2928] TRACE o.c.frontend.dokany.ReadWriteAdapter - (126) getFileInformation() is called for /.
16:46:17.582 [Thread-2928] TRACE o.c.frontend.dokany.ReadWriteAdapter - (126) Filesize of / is 4096.
16:46:17.582 [Thread-2928] TRACE o.c.frontend.dokany.ReadWriteAdapter - (126) File Information successful read from /.
16:46:17.582 [Thread-2929] TRACE o.c.frontend.dokany.ReadWriteAdapter - (125) findFiles() is called for /.
16:46:17.582 [Thread-2929] TRACE o.c.c.dir.CryptoDirectoryStream - OPEN
16:46:17.583 [Thread-2929] TRACE o.c.frontend.dokany.ReadWriteAdapter - (125) findFiles(): found file WELCOME.rtf
16:46:17.583 [Thread-2929] TRACE o.c.frontend.dokany.ReadWriteAdapter - (125) Successful searched content in /.
16:46:17.584 [Thread-2929] TRACE o.c.c.dir.CryptoDirectoryStream - CLOSE
16:46:17.584 [Thread-2930] TRACE o.c.frontend.dokany.ReadWriteAdapter - (126) findFiles() is called for /.
16:46:17.585 [Thread-2930] TRACE o.c.c.dir.CryptoDirectoryStream - OPEN
16:46:17.586 [Thread-2930] TRACE o.c.frontend.dokany.ReadWriteAdapter - (126) findFiles(): found file WELCOME.rtf
16:46:17.586 [Thread-2930] TRACE o.c.frontend.dokany.ReadWriteAdapter - (126) Successful searched content in /.
16:46:17.586 [Thread-2930] TRACE o.c.c.dir.CryptoDirectoryStream - CLOSE
16:46:17.598 [Thread-2931] TRACE o.c.frontend.dokany.ReadWriteAdapter - (125) cleanup() is called for /.
16:46:17.601 [Thread-2933] TRACE o.c.frontend.dokany.ReadWriteAdapter - (126) cleanup() is called for /.
16:46:17.601 [Thread-2932] TRACE o.c.frontend.dokany.ReadWriteAdapter - (125) closeFile() is called for /.
16:46:17.626 [Thread-2934] TRACE o.c.frontend.dokany.ReadWriteAdapter - (126) closeFile() is called for /.
16:46:17.626 [Thread-2935] TRACE o.c.frontend.dokany.ReadWriteAdapter - zwCreateFile() is called for / with the following parameters:
CreateDisposition -- OPEN_EXISTING
createOptions -- EnumIntegerSet(elements=[FILE_DIRECTORY_FILE, FILE_SYNCHRONOUS_IO_NONALERT])
accessMasks -- EnumIntegerSet(elements=[SYNCHRONIZE])
fileAccessMasks -- EnumIntegerSet(elements=[])
fileAttributes -- EnumIntegerSet(elements=[]).
16:46:17.626 [Thread-2935] TRACE o.c.frontend.dokany.ReadWriteAdapter - Try to open / as Directory.
16:46:17.627 [Thread-2935] TRACE o.c.frontend.dokany.ReadWriteAdapter - (127) / opened successful with handle 127.
16:46:17.627 [Thread-2938] TRACE o.c.frontend.dokany.ReadWriteAdapter - (127) cleanup() is called for /.
16:46:17.628 [Thread-2939] TRACE o.c.frontend.dokany.ReadWriteAdapter - (127) closeFile() is called for /.
16:46:17.628 [Thread-2940] TRACE o.c.frontend.dokany.ReadWriteAdapter - zwCreateFile() is called for / with the following parameters:
16:46:17.628 [Thread-2940] TRACE o.c.frontend.dokany.ReadWriteAdapter - Try to open / as Directory.
16:46:17.628 [Thread-2940] TRACE o.c.frontend.dokany.ReadWriteAdapter - (128) / opened successful with handle 128.
16:46:17.653 [Thread-2943] TRACE o.c.frontend.dokany.ReadWriteAdapter - zwCreateFile() is called for / with the following parameters:
16:46:17.653 [Thread-2944] TRACE o.c.frontend.dokany.ReadWriteAdapter - (128) cleanup() is called for /.
16:46:17.653 [Thread-2943] TRACE o.c.frontend.dokany.ReadWriteAdapter - Try to open / as Directory.
16:46:17.653 [Thread-2943] TRACE o.c.frontend.dokany.ReadWriteAdapter - (129) / opened successful with handle 129.
16:46:17.654 [Thread-2945] TRACE o.c.frontend.dokany.ReadWriteAdapter - (128) closeFile() is called for /.
16:46:17.676 [Thread-2948] TRACE o.c.frontend.dokany.ReadWriteAdapter - (129) cleanup() is called for /.
16:46:17.684 [Thread-2949] TRACE o.c.frontend.dokany.ReadWriteAdapter - (129) closeFile() is called for /.
16:46:17.684 [Thread-2950] TRACE o.c.frontend.dokany.ReadWriteAdapter - zwCreateFile() is called for / with the following parameters:
16:46:17.684 [Thread-2950] TRACE o.c.frontend.dokany.ReadWriteAdapter - Try to open / as Directory.
16:46:17.684 [Thread-2950] TRACE o.c.frontend.dokany.ReadWriteAdapter - (130) / opened successful with handle 130.
16:46:17.689 [Thread-2953] TRACE o.c.frontend.dokany.ReadWriteAdapter - (130) cleanup() is called for /.
16:46:17.694 [Thread-2954] TRACE o.c.frontend.dokany.ReadWriteAdapter - (130) closeFile() is called for /.
16:46:17.942 [Thread-2955] TRACE o.c.frontend.dokany.ReadWriteAdapter - zwCreateFile() is called for / with the following parameters:
createOptions -- EnumIntegerSet(elements=[])
accessMasks -- EnumIntegerSet(elements=[])
16:46:17.942 [Thread-2955] TRACE o.c.frontend.dokany.ReadWriteAdapter - Try to open / as Directory.
16:46:17.942 [Thread-2955] TRACE o.c.frontend.dokany.ReadWriteAdapter - (131) / opened successful with handle 131.
16:46:17.943 [Thread-2956] TRACE o.c.frontend.dokany.ReadWriteAdapter - (131) getFileInformation() is called for /.
16:46:17.943 [Thread-2956] TRACE o.c.frontend.dokany.ReadWriteAdapter - (131) Filesize of / is 4096.
16:46:17.943 [Thread-2956] TRACE o.c.frontend.dokany.ReadWriteAdapter - (131) File Information successful read from /.
16:46:17.944 [Thread-2957] TRACE o.c.frontend.dokany.ReadWriteAdapter - (131) cleanup() is called for /.
16:46:17.945 [Thread-2958] TRACE o.c.frontend.dokany.ReadWriteAdapter - (131) closeFile() is called for /.
16:46:18.343 [Thread-2959] TRACE o.c.frontend.dokany.ReadWriteAdapter - zwCreateFile() is called for / with the following parameters:
16:46:18.343 [Thread-2960] TRACE o.c.frontend.dokany.ReadWriteAdapter - zwCreateFile() is called for / with the following parameters:
16:46:18.343 [Thread-2959] TRACE o.c.frontend.dokany.ReadWriteAdapter - Try to open / as Directory.
16:46:18.343 [Thread-2959] TRACE o.c.frontend.dokany.ReadWriteAdapter - (132) / opened successful with handle 132.
16:46:18.343 [Thread-2960] TRACE o.c.frontend.dokany.ReadWriteAdapter - Try to open / as Directory.
16:46:18.344 [Thread-2960] TRACE o.c.frontend.dokany.ReadWriteAdapter - (133) / opened successful with handle 133.
16:46:18.346 [Thread-2961] TRACE o.c.frontend.dokany.ReadWriteAdapter - (132) getFileInformation() is called for /.
16:46:18.346 [Thread-2961] TRACE o.c.frontend.dokany.ReadWriteAdapter - (132) Filesize of / is 4096.
16:46:18.346 [Thread-2961] TRACE o.c.frontend.dokany.ReadWriteAdapter - (132) File Information successful read from /.
16:46:18.347 [Thread-2963] TRACE o.c.frontend.dokany.ReadWriteAdapter - (132) cleanup() is called for /.
16:46:18.348 [Thread-2964] TRACE o.c.frontend.dokany.ReadWriteAdapter - (132) closeFile() is called for /.
16:46:18.350 [Thread-2966] TRACE o.c.frontend.dokany.ReadWriteAdapter - (133) cleanup() is called for /.
16:46:18.351 [Thread-2967] TRACE o.c.frontend.dokany.ReadWriteAdapter - (133) closeFile() is called for /.
16:46:18.378 [Thread-2968] TRACE o.c.frontend.dokany.ReadWriteAdapter - zwCreateFile() is called for / with the following parameters:
16:46:18.378 [Thread-2968] TRACE o.c.frontend.dokany.ReadWriteAdapter - Try to open / as Directory.
16:46:18.379 [Thread-2968] TRACE o.c.frontend.dokany.ReadWriteAdapter - (134) / opened successful with handle 134.
16:46:18.379 [Thread-2969] TRACE o.c.frontend.dokany.ReadWriteAdapter - (134) getFileInformation() is called for /.
16:46:18.380 [Thread-2969] TRACE o.c.frontend.dokany.ReadWriteAdapter - (134) Filesize of / is 4096.
16:46:18.380 [Thread-2969] TRACE o.c.frontend.dokany.ReadWriteAdapter - (134) File Information successful read from /.
16:46:18.386 [Thread-2970] TRACE o.c.frontend.dokany.ReadWriteAdapter - (134) cleanup() is called for /.
16:46:18.386 [Thread-2971] TRACE o.c.frontend.dokany.ReadWriteAdapter - (134) closeFile() is called for /.
16:46:18.426 [Thread-2972] TRACE o.c.frontend.dokany.ReadWriteAdapter - zwCreateFile() is called for / with the following parameters:
16:46:18.426 [Thread-2972] TRACE o.c.frontend.dokany.ReadWriteAdapter - Try to open / as Directory.
16:46:18.426 [Thread-2972] TRACE o.c.frontend.dokany.ReadWriteAdapter - (135) / opened successful with handle 135.
16:46:18.427 [Thread-2973] TRACE o.c.frontend.dokany.ReadWriteAdapter - (135) getFileInformation() is called for /.
16:46:18.427 [Thread-2973] TRACE o.c.frontend.dokany.ReadWriteAdapter - (135) Filesize of / is 4096.
16:46:18.427 [Thread-2973] TRACE o.c.frontend.dokany.ReadWriteAdapter - (135) File Information successful read from /.
16:46:18.428 [Thread-2974] TRACE o.c.frontend.dokany.ReadWriteAdapter - (135) cleanup() is called for /.
16:46:18.429 [Thread-2975] TRACE o.c.frontend.dokany.ReadWriteAdapter - (135) closeFile() is called for /.
16:46:19.394 [Thread-2976] TRACE o.c.frontend.dokany.ReadWriteAdapter - zwCreateFile() is called for / with the following parameters:
16:46:19.394 [Thread-2976] TRACE o.c.frontend.dokany.ReadWriteAdapter - Try to open / as Directory.
16:46:19.395 [Thread-2976] TRACE o.c.frontend.dokany.ReadWriteAdapter - (136) / opened successful with handle 136.
16:46:19.395 [Thread-2977] TRACE o.c.frontend.dokany.ReadWriteAdapter - (136) getFileInformation() is called for /.
16:46:19.395 [Thread-2977] TRACE o.c.frontend.dokany.ReadWriteAdapter - (136) Filesize of / is 4096.
16:46:19.395 [Thread-2978] TRACE o.c.frontend.dokany.ReadWriteAdapter - zwCreateFile() is called for / with the following parameters:
16:46:19.395 [Thread-2977] TRACE o.c.frontend.dokany.ReadWriteAdapter - (136) File Information successful read from /.
16:46:19.396 [Thread-2978] TRACE o.c.frontend.dokany.ReadWriteAdapter - Try to open / as Directory.
16:46:19.396 [Thread-2978] TRACE o.c.frontend.dokany.ReadWriteAdapter - (137) / opened successful with handle 137.
16:46:19.396 [Thread-2979] TRACE o.c.frontend.dokany.ReadWriteAdapter - (136) cleanup() is called for /.
16:46:19.396 [Thread-2981] TRACE o.c.frontend.dokany.ReadWriteAdapter - (136) closeFile() is called for /.
16:46:19.396 [Thread-2983] TRACE o.c.frontend.dokany.ReadWriteAdapter - (137) cleanup() is called for /.
16:46:19.397 [Thread-2984] TRACE o.c.frontend.dokany.ReadWriteAdapter - (137) closeFile() is called for /.
16:46:19.727 [Thread-2985] TRACE o.c.frontend.dokany.ReadWriteAdapter - zwCreateFile() is called for / with the following parameters:
16:46:19.727 [Thread-2985] TRACE o.c.frontend.dokany.ReadWriteAdapter - Try to open / as Directory.
16:46:19.727 [Thread-2985] TRACE o.c.frontend.dokany.ReadWriteAdapter - (138) / opened successful with handle 138.
16:46:19.728 [Thread-2988] TRACE o.c.frontend.dokany.ReadWriteAdapter - (138) cleanup() is called for /.
16:46:19.729 [Thread-2989] TRACE o.c.frontend.dokany.ReadWriteAdapter - (138) closeFile() is called for /.
16:46:19.755 [Thread-2990] TRACE o.c.frontend.dokany.ReadWriteAdapter - zwCreateFile() is called for / with the following parameters:
16:46:19.755 [Thread-2990] TRACE o.c.frontend.dokany.ReadWriteAdapter - Try to open / as Directory.
16:46:19.756 [Thread-2990] TRACE o.c.frontend.dokany.ReadWriteAdapter - (139) / opened successful with handle 139.
16:46:19.758 [Thread-2991] TRACE o.c.frontend.dokany.ReadWriteAdapter - (139) getFileInformation() is called for /.
16:46:19.758 [Thread-2991] TRACE o.c.frontend.dokany.ReadWriteAdapter - (139) Filesize of / is 4096.
16:46:19.758 [Thread-2991] TRACE o.c.frontend.dokany.ReadWriteAdapter - (139) File Information successful read from /.
16:46:19.759 [Thread-2992] TRACE o.c.frontend.dokany.ReadWriteAdapter - (139) cleanup() is called for /.
16:46:19.759 [Thread-2993] TRACE o.c.frontend.dokany.ReadWriteAdapter - (139) closeFile() is called for /.
16:46:19.760 [Thread-2994] TRACE o.c.frontend.dokany.ReadWriteAdapter - (6) cleanup() is called for /.
16:46:19.760 [Thread-2995] TRACE o.c.frontend.dokany.ReadWriteAdapter - (6) closeFile() is called for /.
16:46:19.760 [Thread-2996] TRACE o.c.frontend.dokany.ReadWriteAdapter - (7) cleanup() is called for /.
16:46:19.761 [Thread-2997] TRACE o.c.frontend.dokany.ReadWriteAdapter - (7) closeFile() is called for /.
16:46:21.456 [JavaFX Application Thread] INFO o.cryptomator.ui.common.VaultService - Revealed Testing
16:46:39.662 [JavaFX Application Thread] DEBUG o.cryptomator.ui.fxapp.FxApplication - Showing Preferences
16:47:05.986 [JavaFX Application Thread] INFO o.cryptomator.ui.common.VaultService - Revealed Testing
16:47:08.618 [JavaFX Application Thread] INFO o.cryptomator.ui.common.VaultService - Revealed Testing
