Started using Photo-Upload some time ago. Suddenly it stopped working with a “general error”. I can find this entry in log-file for each try:
ErrorCode: PJ2D:5NHN
I 20210425163707.172 App Cryptors service connected
I 20210425163707.179 App Auto upload service connected
I 20210425163707.186 PhotoContentJob Job rescheduled!
I 20210425163707.193 PhotoContentJob Service is destroyed
I 20210425163733.708 App Cryptomator v1.5.13 (2099) "APK Store Edition" started on android 11 / API30 using a SM-A515F
D 20210425163733.712 App appId org.cryptomator
D 20210425163733.758 CryptorsService created
D 20210425163733.799 AutoUploadService created
I 20210425163733.807 PhotoContentJob Job started!
I 20210425163733.906 FileUtil Try to recover AutoUploadFilesStore using class c or a
E 20210425163733.911 PhotoContentJob Failed to add image to auto upload list
org.cryptomator.domain.exception.FatalBackendException: Failed to recover AutoUploadFilesStore
at org.cryptomator.presentation.util.FileUtil.tryRecoverAutoUploadFilesStoreDueToFileObfuscation(FileUtil.kt:230)
at org.cryptomator.presentation.util.FileUtil.getAutoUploadFilesStore(FileUtil.kt:197)
at org.cryptomator.presentation.util.FileUtil.addImageToAutoUploads(FileUtil.kt:155)
at org.cryptomator.presentation.service.PhotoContentJob.onStartJob(PhotoContentJob.kt:52)
at android.app.job.JobService$1.onStartJob(JobService.java:62)
at android.app.job.JobServiceEngine$JobHandler.handleMessage(JobServiceEngine.java:108)
at android.os.Handler.dispatchMessage(Handler.java:106)
at android.os.Looper.loop(Looper.java:246)
at android.app.ActivityThread.main(ActivityThread.java:8443)
at java.lang.reflect.Method.invoke(Native Method)
at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:596)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1130)
Caused by: java.io.InvalidClassException: org.cryptomator.presentation.e.c; local class incompatible: stream classdesc serialVersionUID = 7809473971931047958, local class serialVersionUID = -2190476748996271234
at java.io.ObjectStreamClass.initNonProxy(ObjectStreamClass.java:624)
at java.io.ObjectInputStream.readNonProxyDesc(ObjectInputStream.java:1713)
at java.io.ObjectInputStream.readClassDesc(ObjectInputStream.java:1594)
at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1872)
at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1412)
at java.io.ObjectInputStream.readObject(ObjectInputStream.java:427)
at org.cryptomator.presentation.util.FileUtil.tryRecoverAutoUploadFilesStoreDueToFileObfuscation(FileUtil.kt:215)
... 11 more
What i already tried without success:
- create another vault and use it for photo-upload
- enabling / disabling the auto-upload feature
- disable “wifi-only” option
Any help is really appreciated.
