Applications crash when stored in crypto vault 1.17.1
As soon as I try to save an Excel file from Excel into a crypto vault, Excel completely crashes. Even ending the process via task management then fails. The only thing that helps to solve the Excel crash is to forcefully close cryptomator. (Saving from Excel to the Crypto Vault is therefore completely impossible)
The same happens with the Windows Kindle app, where the content folder is in Vault.
The cryptovault is on a normal Pcloud drive.
I hope this can be fixed with a future software update ASAP.
Thanks in advance.
Welcome to the Cryptomator community :slightly_smiling_face:
there is a ticket on the issue tracker which describes a freezing of Windows Explorer when using PCloud with Cryptomator, see PCloud + WIndows 10: Intermittent freezes · Issue #3473 · cryptomator/cryptomator · GitHub
Maybe it is the same issue/has the same root cause.
