Hello, I’ve saved the AppImage in my OpenSuse Tumbleweed (Kde Plasma) system.
I’ve disabled the KDE Wallet service.
When i run the appimage, the whole system freezes. Killing Cryptomator, everything start to work fine again. So it seems a Cryptomator problem. Executing the AppImage from the terminal I get:
21:56:02.777 [main] INFO o.c.common.settings.SettingsProvider - Settings loaded from /home/enrico/.config/Cryptomator/settings.json
21:56:02.801 [main] INFO org.cryptomator.common.Environment - user.home: /home/enrico
21:56:02.802 [main] INFO org.cryptomator.common.Environment - java.library.path: :/tmp/.mount_cryptoJGllvv/lib/app:/usr/java/packages/lib:/usr/lib64:/lib64:/lib:/usr/lib
21:56:02.802 [main] INFO org.cryptomator.common.Environment - user.language: it
21:56:02.802 [main] INFO org.cryptomator.common.Environment - user.region: null
21:56:02.802 [main] INFO org.cryptomator.common.Environment - logback.configurationFile: null
21:56:02.802 [main] INFO org.cryptomator.common.Environment - cryptomator.settingsPath: ~/.config/Cryptomator/settings.json:~/.Cryptomator/settings.json
21:56:02.802 [main] INFO org.cryptomator.common.Environment - cryptomator.ipcSocketPath: ~/.config/Cryptomator/ipc.socket
21:56:02.803 [main] INFO org.cryptomator.common.Environment - cryptomator.integrationsWin.keychainPaths: null
21:56:02.803 [main] INFO org.cryptomator.common.Environment - cryptomator.logDir: ~/.local/share/Cryptomator/logs
21:56:02.803 [main] INFO org.cryptomator.common.Environment - cryptomator.pluginDir: ~/.local/share/Cryptomator/plugins
21:56:02.803 [main] INFO org.cryptomator.common.Environment - cryptomator.mountPointsDir: ~/.local/share/Cryptomator/mnt
21:56:02.803 [main] INFO org.cryptomator.common.Environment - cryptomator.minPwLength: null
21:56:02.803 [main] INFO org.cryptomator.common.Environment - cryptomator.appVersion: 1.6.15
21:56:02.804 [main] INFO org.cryptomator.common.Environment - cryptomator.buildNumber: appimage-3983
21:56:02.804 [main] INFO org.cryptomator.common.Environment - cryptomator.showTrayIcon: false
21:56:02.804 [main] INFO org.cryptomator.common.Environment - cryptomator.p12Path: ~/.config/Cryptomator/key.p12
21:56:02.804 [main] INFO o.cryptomator.launcher.Cryptomator - Starting Cryptomator 1.6.15 on Linux 6.0.10-1-default (amd64)
21:56:02.852 [main] INFO org.cryptomator.ipc.Server - Spawning IPC server listening on socket /home/enrico/.config/Cryptomator/ipc.socket
(Cryptomator:1919): dbind-WARNING **: 21:56:03.157: AT-SPI: Error retrieving accessibility bus address: org.freedesktop.DBus.Error.ServiceUnknown: The name org.a11y.Bus was not provided by any .service files
21:56:03.674 [JavaFX Application Thread] INFO o.cryptomator.launcher.Cryptomator - JavaFX runtime started after 1429ms
Dec 05, 2022 9:56:04 PM com.sun.javafx.css.StyleManager loadStylesheetUnPrivileged
INFORMAZIONI: Could not load @font-face font [file:/home/runner/work/cryptomator/cryptomator/src/main/resources/css/opensans_regular.ttf]
INFORMAZIONI: Could not load @font-face font [file:/home/runner/work/cryptomator/cryptomator/src/main/resources/css/opensans_semibold.ttf]
INFORMAZIONI: Could not load @font-face font [file:/home/runner/work/cryptomator/cryptomator/src/main/resources/css/opensans_bold.ttf]
21:56:18.214 [JavaFX Application Thread] INFO o.f.dbus.handlers.SignalHandler - Await signal org.kde.KWallet$walletAsyncOpened(/modules/kwalletd5) within 120 seconds.
