Any dependencies required to be installed separately for 1.6.x?
Do the 1.6.x versions require any dependencies to be installed separately on Windows? For example I think the 1.4.x versions required Visual C++ Redistributable to be installed separately if I am not mistaken. Does everything now come with the default .exe installer? I plan to use this with WinFsp on Windows 10/11 (fresh installation). I believe WinFsp is included already in the .exe, is there any other requirement/dependency?
Thank you
Yes. Included is WinFSP if you check the select box. No need to install anything separately.
