Android Cryptomator connecting to synology
try to connect my Android mobile Cryptomator from the WWW with synology815 as my cloud.
Sinology has WEBDAV installed and running. In the file is a masterkey and vault. Works perfect with Win10.
Fritzbox 7690, DSM ok, port forwarding 5006 and/or 443 is useless. Quickconnect is working.
The error is server scheint nicht webdav kompatibel zu sein
Is there somebody who helps me, perhaps step by step?
Would appreciate it. Thanks chris
Hey and welcome to the Cryptomator Community :slightly_frowning_face:,
Are you sure you entered the correct URL of the WebDAV endpoint?
