Hello, since I have upgraded cryptomator to version 1.5.0 and now 1.5.3, I am having this error when I try to open my vault, I am using iCloud from apple. This is the error, any help is highly appreciated.
02:45:38.549 [JavaFX Application Thread] ERROR o.c.ui.unlock.UnlockController - Unlock failed for technical reasons.
java.io.IOException: Error during file system creation.
at org.cryptomator.cryptofs.CryptoFileSystems.create(CryptoFileSystems.java:53)
at org.cryptomator.cryptofs.CryptoFileSystemProvider.newFileSystem(CryptoFileSystemProvider.java:302)
at org.cryptomator.cryptofs.CryptoFileSystemProvider.newFileSystem(CryptoFileSystemProvider.java:94)
at org.cryptomator.cryptofs.CryptoFileSystemProvider.newFileSystem(CryptoFileSystemProvider.java:135)
at org.cryptomator.common.vaults.Vault.unlockCryptoFileSystem(Vault.java:120)
at org.cryptomator.common.vaults.Vault.lambda$getCryptoFileSystem$0(Vault.java:98)
at java.base/java.util.concurrent.atomic.AtomicReference.updateAndGet(Unknown Source)
at org.cryptomator.common.vaults.Vault.getCryptoFileSystem(Vault.java:98)
at org.cryptomator.common.vaults.Vault.unlock(Vault.java:127)
at org.cryptomator.ui.common.VaultService$UnlockVaultTask.call(VaultService.java:299)
at org.cryptomator.ui.common.VaultService$UnlockVaultTask.call(VaultService.java:278)
Caused by: java.io.UncheckedIOException: java.nio.file.FileSystemException: C:\Users\johnc.JECPC\iCloudDrive\iCloud~com~setolabs~Cryptomator\JC-STAR\masterkey.cryptomator.B5756B25.bkup: The handle is invalid
at org.cryptomator.cryptofs.CryptoFileSystemModule.provideCryptor(CryptoFileSystemModule.java:42)
at org.cryptomator.cryptofs.CryptoFileSystemModule_ProvideCryptorFactory.provideCryptor(CryptoFileSystemModule_ProvideCryptorFactory.java:56)
at org.cryptomator.cryptofs.CryptoFileSystemModule_ProvideCryptorFactory.get(CryptoFileSystemModule_ProvideCryptorFactory.java:43)
at org.cryptomator.cryptofs.DaggerCryptoFileSystemProviderComponent$CryptoFileSystemComponentImpl.cryptoFileSystem(DaggerCryptoFileSystemProviderComponent.java:325)
... 19 common frames omitted
Caused by: java.nio.file.FileSystemException: C:\Users\johnc.JECPC\iCloudDrive\iCloud~com~setolabs~Cryptomator\JC-STAR\masterkey.cryptomator.B5756B25.bkup: The handle is invalid
at java.base/sun.nio.fs.WindowsFileCopy.copy(Unknown Source)
at java.base/sun.nio.fs.WindowsFileSystemProvider.copy(Unknown Source)
at java.base/java.nio.file.Files.copy(Unknown Source)
at org.cryptomator.cryptofs.CryptoFileSystemModule.backupMasterkeyFileIfRequired(CryptoFileSystemModule.java:48)
at org.cryptomator.cryptofs.CryptoFileSystemModule.provideCryptor(CryptoFileSystemModule.java:39)
... 30 common frames omitted
02:46:01.583 [JavaFX Application Thread] ERROR o.c.ui.unlock.UnlockController - Unlock failed for technical reasons.
02:47:16.470 [JavaFX Application Thread] ERROR o.c.ui.unlock.UnlockController - Unlock failed for technical reasons.
02:51:52.486 [main] INFO org.cryptomator.launcher.Cryptomator - Starting Cryptomator 1.5.3 on Windows 10 10.0 (amd64)
02:51:52.727 [main] INFO org.cryptomator.launcher.Cryptomator - Found running application instance. Shutting down...
Thank You for all your help, I love this program and I was not having any issues before version 1.5.0
At: JC
