My preferred username seems to be available. I didn’t realize it was, before settling on the current username. Is it possible to change, or would I need to create a second account?
Yes, you can. Click your profile picture at the top-right. Select the right tab with the “user silhouette” icon and then “Preferences”. Under “Account”, you can change your username.
Thank you for sharing that! I am not able to locate the part where I can edit the username though. I see an option to edit the name instead.
Sent you a direct message. I can change it for you.
Thank you for reaching out!
Can I also request a username change? (Or would it be better to open another post with the request?)
Thank you!
Just sent you a direct message.
Hi there @SailReal If possible, I would appreciate a username change, also. I do not have the option to change it manually under the specified settings.
