I created a vault on microsd card. When I am copying files to that folder, it always had the below popup. Even it was my first time using that vault, and no matter what files I copied. Help
#cryptomatorcryptomator
To help you, one does need to know the answer to the follwing questions:
Furthermore, does this also appear if you are creating a new vault on your local hard drive or just for this specific vault?
The error appears only for vaults created inside microsd card. Local hard drive is fine, no problem
