This is what that shows (BTW that was after replacing ui-1.5.0.jar inside Cryptomator.app).
18:45:14.154 [main] DEBUG org.cryptomator.common.Environment - java.library.path: /Applications/Cryptomator.app/Contents/Java:/Applications/Cryptomator.app/Contents/MacOS:/usr/local/lib
18:45:14.157 [main] DEBUG org.cryptomator.common.Environment - user.language: en
18:45:14.157 [main] DEBUG org.cryptomator.common.Environment - user.region: null
18:45:14.158 [main] DEBUG org.cryptomator.common.Environment - logback.configurationFile: null
18:45:14.158 [main] DEBUG org.cryptomator.common.Environment - cryptomator.settingsPath: ~/Library/Application Support/Cryptomator/settings.json
18:45:14.158 [main] DEBUG org.cryptomator.common.Environment - cryptomator.ipcPortPath: ~/Library/Application Support/Cryptomator/ipcPort.bin
18:45:14.158 [main] DEBUG org.cryptomator.common.Environment - cryptomator.keychainPath: null
18:45:14.158 [main] DEBUG org.cryptomator.common.Environment - cryptomator.logDir: ~/Library/Logs/Cryptomator
18:45:14.158 [main] DEBUG org.cryptomator.common.Environment - cryptomator.mountPointsDir: /Volumes
18:45:14.158 [main] DEBUG org.cryptomator.common.Environment - cryptomator.minPwLength: null
18:45:14.158 [main] DEBUG org.cryptomator.common.Environment - cryptomator.buildNumber: dmg-2139.102
18:45:14.186 [main] DEBUG org.cryptomator.common.ShutdownHook - Registered shutdown hook.
18:45:14.248 [main] DEBUG org.cryptomator.common.settings.SettingsProvider - Attempting to load settings from /Users/xxx/Library/Application Support/Cryptomator/settings.json
18:45:14.287 [main] INFO org.cryptomator.common.settings.SettingsProvider - Settings loaded from /Users/xxx/Library/Application Support/Cryptomator/settings.json
Exception in thread "main" java.lang.IllegalStateException: Not a JSON Object: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"
at com.google.gson.JsonElement.getAsJsonObject(JsonElement.java:91)
at org.cryptomator.cryptolib.api.KeyFile.parse(KeyFile.java:81)
at org.cryptomator.cryptofs.migration.Migrators.needsMigration(Migrators.java:81)
at org.cryptomator.common.vaults.VaultListManager.determineVaultState(VaultListManager.java:90)
at org.cryptomator.common.vaults.VaultListManager.create(VaultListManager.java:81)
at java.base/java.util.stream.ReferencePipeline$3$1.accept(ReferencePipeline.java:195)
at java.base/java.util.AbstractList$RandomAccessSpliterator.forEachRemaining(AbstractList.java:720)
at java.base/java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:484)
at java.base/java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:474)
at java.base/java.util.stream.ReduceOps$ReduceOp.evaluateSequential(ReduceOps.java:913)
at java.base/java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234)
at java.base/java.util.stream.ReferencePipeline.collect(ReferencePipeline.java:578)
at org.cryptomator.common.vaults.VaultListManager.addAll(VaultListManager.java:66)
at org.cryptomator.common.vaults.VaultListManager.<init>(VaultListManager.java:41)
at org.cryptomator.common.vaults.VaultListManager_Factory.newInstance(VaultListManager_Factory.java:40)
at org.cryptomator.common.vaults.VaultListManager_Factory.get(VaultListManager_Factory.java:29)
at org.cryptomator.common.vaults.VaultListManager_Factory.get(VaultListManager_Factory.java:8)
at org.cryptomator.common.CommonsModule_ProvideVaultListFactory.get(CommonsModule_ProvideVaultListFactory.java:29)
at org.cryptomator.common.CommonsModule_ProvideVaultListFactory.get(CommonsModule_ProvideVaultListFactory.java:11)
at org.cryptomator.ui.launcher.UiLauncher_Factory.get(UiLauncher_Factory.java:50)
at org.cryptomator.ui.launcher.UiLauncher_Factory.get(UiLauncher_Factory.java:13)
at org.cryptomator.launcher.Cryptomator_Factory.get(Cryptomator_Factory.java:47)
at org.cryptomator.launcher.Cryptomator_Factory.get(Cryptomator_Factory.java:12)
at org.cryptomator.launcher.DaggerCryptomatorComponent.application(DaggerCryptomatorComponent.java:523)
at org.cryptomator.launcher.Cryptomator.main(Cryptomator.java:48)
18:45:16.375 [ShutdownTasks] DEBUG org.cryptomator.common.ShutdownHook - Running graceful shutdown tasks...
2020-04-20 18:45:16.736 Cryptomator[23828:1247150] Cryptomator:Failed to launch JVM
