Access to a vault in onedrive
I have created a “vault” in OneDrive and I need to share those files but they are only visible in the local OneDrive folder, how can I do? I want to access them through the link in onedrive. Thank you.
The sync to your onedrive is done by the onedrive client. Please make sure that the onedrive client is running.
You cant do that, because your files are encrypted now.
If you want to share your encrypted files, you have to share the vault. Means you’ll have to grant access to your encrypted vault files in your onedrive, and then share the password of your vault with anyone you want to have access. The recipients must use Cryptomator to access the vault.
