A shared OneDrive folder (vault) does not appear in Cryptomator iOS App
Since a few days it is no longer possible to select a shared OneDrive folder (vault), which appears as a “linked” folder in the Cryptomator iOS-App.
Before everything worked fine.
Maybe the latest iOS Update a few days ago (18.4) caused the problem.
Or maybe Microsoft has changed thing.
Or maybe Cryptomator has changed things.
A possible Workaround could be using WebDav instead, but for me thats not a satisfying workaround because then I need to use the OneDrive-ID and the user/pass from the owner of the shared folder to connect through WebDav. That is obviously not a good idea even if we both trust each other. Because system-wide on iOS you use your own Microsoft Account (for OneDrve, OneNote, etc.) and then in Cryptomator you use the owners-shared-folder-Login-details?! That may cause other problems beyond security aspects.
So please give a better advice!
Thank you very much in advance.
Greetings
I can confirm the issue on Android app too. So, perhaps OneDrive modified the API response?
The topic on Android is here OneDrive Access to shared folders
