Hi, Spotlight working with Cryptomator is a deal breaker for me. I understand it has been broken for years now.
Is there likely to be a concerted effort by the developers where the code for Cryptomator is likely to materially change where this becomes a top priority so that Spotlight can work, and be sustainable. I get MacOS has significantly evolved and to achieve this really will require a significant re-write. My question is - is it likely to happen? My understanding that the entire way a drive mounts with fusion would have to change as well.
My second question - if using google drive (streaming, not having all the files downloaded and stored locally) will cryptomator work, and secondly, can I share that cryptomator drive with someone else so that we both have access to it and it syncs using streaming so we both have the same copy?
With thanks.
