90 seconds delay mounting WebDAV (macOS)
I’m seeing a 90 seconds delay when unlocking a vault with “WebDAV (AppleScript)”. I believe this issue showed up after upgrading to macOS 15.5.
Debug log: gist:2d87b5dde3648c86e07e9394faf390b8 · GitHub
No delay with FUSE-T. No delay when mounting as “WebDAV (HTTP Address)”, but then a 90 seconds delay when mounting that address in Finder.
It sounds exactly like Volumetype WebDAV (Applescript): Not working on on macOS 15.4 · Issue #3806 · cryptomator/cryptomator · GitHub. But that is marked as fixed in 1.15.2. I’m using 1.16.1.
I can confirm this issue, and thank you for reporting it. I believe to know why our fix doesn’t work anymore on macOS 15.5. If it’s true, we should be able to release a hotfix by the end of this week.
Fixed in Release 1.16.2 (macOS only) · cryptomator/cryptomator · GitHub.
Thank you! The new version works for me.
