Is it possible to add 2FA to the iOS app and/or the Windows app?
I see the forum has it, but I noticed the Desktop nor the iphone app has it.
I don’t know about the IOS app but there is a way to have essentially two factor Authentication in Windows if you use the cryptonator plugin for keepass XC password manager.
You wouldn’t need to use keepass XC as your primary password manager, it would control access to your vaults only and you can have two-factor authentication that way. My keypass XC is linked to my cryptomator. When I launch keepass XC I have two-factor authentication enabled so it asks me not only for the password but my windows hello thumbprint as well.
That is the only way that I’m aware of that you can add a extra layer of Authentication to the Windows app.
