Hello to all,
After installing a brand new version of Windows 10 ver 21H1 (from a formatting of the disk and then completely setting up my Windows), I managed to install version 1.6.1.
I now have the following problem (I’m doing a mount with FUSE) this message appears all the time.
Should I change and install Dokany to avoid this risky problem?
Thanks for your advice
