I have just upgraded from 1.3.4 to 1.4.0 and wanted to use the new Dokany-framework in order to mount my volume instead of Webdav.
Unforunately it fails all the time. I manually uninstalled Dokany, rebooted and installed v 1.2.0.1000 (https://github.com/dokan-dev/dokany/releases/tag/v1.2.0.1000), which is the same that comes with the cryptomator but it didn’t help at all.
Using WebDav instead works just fine.
Attached you can find Cryptomator’s debug log.
10:57:00.057 [main] INFO org.cryptomator.launcher.Cryptomator - Starting Cryptomator 1.4.0 on Windows 10 10.0 (amd64)
10:57:00.320 [main] INFO o.c.launcher.FileOpenRequestHandler - Unable to setOpenFileHandler, probably not supported on this OS.
10:57:01.005 [JavaFX Application Thread] INFO o.c.launcher.MainApplication - JavaFX application started.
10:57:01.099 [JavaFX Application Thread] INFO o.c.common.settings.SettingsProvider - Settings loaded from f:\Users\max.mueller\AppData\Roaming\Cryptomator\settings.json
10:57:01.100 [JavaFX Application Thread] DEBUG org.cryptomator.logging.DebugMode - Debug mode initialized
10:57:01.104 [JavaFX Application Thread] DEBUG org.cryptomator.ui.l10n.Localization - Loaded localization default file: /localization/en.txt
10:57:01.104 [JavaFX Application Thread] DEBUG org.cryptomator.ui.l10n.Localization - Detected language "de" and region "DE"
10:57:01.109 [JavaFX Application Thread] TRACE org.cryptomator.ui.l10n.Localization - Attempting to load localization from: /localization/de_DE.txt
10:57:01.109 [JavaFX Application Thread] TRACE org.cryptomator.ui.l10n.Localization - Attempting to load localization from: /localization/de.txt
10:57:01.210 [JavaFX Application Thread] INFO org.cryptomator.jni.JniModule - loaded WinFunctions.dll
10:57:01.254 [JavaFX Application Thread] INFO o.c.ui.controllers.MainController - Unable to setPreferencesHandler, probably not supported on this OS.
10:57:02.223 [JavaFX Application Thread] INFO o.c.ui.controllers.WelcomeController - Current version: 1.4.0, lastest version: 1.4.0
10:57:06.112 [JavaFX Application Thread] INFO o.c.k.WindowsProtectedKeychainAccess - Creating new keychain at path f:\Users\max.mueller\AppData\Roaming\Cryptomator\keychain.json
10:57:08.964 [JavaFX Application Thread] INFO o.c.ui.controllers.WelcomeController - Current version: 1.4.0, lastest version: 1.4.0
10:57:10.039 [JavaFX Application Thread] INFO o.c.k.WindowsProtectedKeychainAccess - Creating new keychain at path f:\Users\max.mueller\AppData\Roaming\Cryptomator\keychain.json
10:57:14.810 [Background Thread 2] INFO com.dokany.java.DokanyDriver - Dokany version: 100
10:57:14.810 [Background Thread 2] INFO com.dokany.java.DokanyDriver - Dokany driver version: 400
10:57:14.810 [Background Thread 2] DEBUG o.c.frontend.dokany.MountFactory - Mounting on P:\: ...
10:57:14.910 [Background Thread 3] TRACE o.c.frontend.dokany.ReadWriteAdapter - mounted() is called.
10:57:17.812 [Background Thread 2] TRACE o.cryptomator.frontend.dokany.Mount - Mounting still in progress.
10:57:17.812 [Background Thread 2] DEBUG o.c.frontend.dokany.MountFactory - Mounted directory at P:\ successfully.
10:57:18.376 [Thread-12] TRACE o.c.frontend.dokany.ReadWriteAdapter - zwCreateFile() is called for / with CreationDisposition OPEN_EXISTING.
10:57:18.378 [Thread-12] TRACE o.c.f.dokany.locks.LockManager - Creating ReadWriteLock for
10:57:18.381 [Thread-12] TRACE o.c.f.dokany.locks.PathWLockImpl - Acquired write path lock for ''
10:57:18.381 [Thread-12] TRACE o.c.f.dokany.locks.LockManager - Creating ReadWriteLock for
10:57:18.382 [Thread-12] TRACE o.c.f.dokany.locks.DataWLockImpl - Acquired write data lock for ''
10:57:18.382 [Thread-12] TRACE o.c.frontend.dokany.ReadWriteAdapter - Try to open / as Directory.
10:57:18.386 [Thread-12] TRACE o.c.frontend.dokany.ReadWriteAdapter - (1) / opened successful with handle 1.
10:57:18.386 [Thread-12] TRACE o.c.f.dokany.locks.DataWLockImpl - Released write data lock for ''
10:57:18.386 [Thread-12] TRACE o.c.f.dokany.locks.PathWLockImpl - Released write path lock for ''
10:57:18.388 [Thread-13] TRACE o.c.frontend.dokany.ReadWriteAdapter - (1) getFileInformation() is called for /.
10:57:18.389 [Thread-13] TRACE o.c.f.dokany.locks.PathRLockImpl - Acquired read path lock for ''
10:57:18.389 [Thread-13] TRACE o.c.f.dokany.locks.DataRLockImpl - Acquired read data lock for ''
10:57:18.402 [Thread-13] TRACE o.c.frontend.dokany.ReadWriteAdapter - (1) File Information successful read from /.
10:57:18.403 [Thread-13] TRACE o.c.f.dokany.locks.DataRLockImpl - Released read data lock for ''
10:57:18.403 [Thread-13] TRACE o.c.f.dokany.locks.PathRLockImpl - Released read path lock for ''
10:57:18.404 [Thread-14] TRACE o.c.frontend.dokany.ReadWriteAdapter - (1) getFileInformation() is called for /.
10:57:18.405 [Thread-14] TRACE o.c.f.dokany.locks.PathRLockImpl - Acquired read path lock for ''
10:57:18.405 [Thread-14] TRACE o.c.f.dokany.locks.DataRLockImpl - Acquired read data lock for ''
10:57:18.407 [Thread-14] TRACE o.c.frontend.dokany.ReadWriteAdapter - (1) File Information successful read from /.
10:57:18.407 [Thread-14] TRACE o.c.f.dokany.locks.DataRLockImpl - Released read data lock for ''
10:57:18.407 [Thread-14] TRACE o.c.f.dokany.locks.PathRLockImpl - Released read path lock for ''
10:57:18.408 [Thread-15] TRACE o.c.frontend.dokany.ReadWriteAdapter - (1) getFileInformation() is called for /.
10:57:18.409 [Thread-15] TRACE o.c.f.dokany.locks.PathRLockImpl - Acquired read path lock for ''
10:57:18.409 [Thread-15] TRACE o.c.f.dokany.locks.DataRLockImpl - Acquired read data lock for ''
10:57:18.411 [Thread-15] TRACE o.c.frontend.dokany.ReadWriteAdapter - (1) File Information successful read from /.
10:57:18.411 [Thread-15] TRACE o.c.f.dokany.locks.DataRLockImpl - Released read data lock for ''
10:57:18.411 [Thread-15] TRACE o.c.f.dokany.locks.PathRLockImpl - Released read path lock for ''
10:57:18.412 [Thread-16] TRACE o.c.frontend.dokany.ReadWriteAdapter - (1) cleanup() is called for /.
10:57:22.944 [JavaFX Application Thread] ERROR o.c.u.controllers.UnlockedController - Reveal failed.
org.cryptomator.ui.model.Volume$VolumeException: Reveal failed.
at org.cryptomator.ui.model.DokanyVolume.reveal(DokanyVolume.java:66)
at org.cryptomator.ui.model.Vault.reveal(Vault.java:161)
at org.cryptomator.ui.controllers.UnlockedController.lambda$revealVault$7(UnlockedController.java:175)
10:57:34.857 [Thread-17] TRACE o.c.frontend.dokany.ReadWriteAdapter - (1) getFileInformation() is called for /.
10:57:34.858 [Thread-17] TRACE o.c.f.dokany.locks.PathRLockImpl - Acquired read path lock for ''
10:57:34.858 [Thread-17] TRACE o.c.f.dokany.locks.DataRLockImpl - Acquired read data lock for ''
10:57:34.860 [Thread-17] TRACE o.c.frontend.dokany.ReadWriteAdapter - (1) File Information successful read from /.
10:57:34.861 [Thread-17] TRACE o.c.f.dokany.locks.DataRLockImpl - Released read data lock for ''
10:57:34.861 [Thread-17] TRACE o.c.f.dokany.locks.PathRLockImpl - Released read path lock for ''
10:57:34.865 [Thread-18] TRACE o.c.frontend.dokany.ReadWriteAdapter - zwCreateFile() is called for / with CreationDisposition OPEN_EXISTING.
10:57:34.867 [Thread-18] TRACE o.c.f.dokany.locks.PathWLockImpl - Acquired write path lock for ''
10:57:34.867 [Thread-18] TRACE o.c.f.dokany.locks.DataWLockImpl - Acquired write data lock for ''
10:57:34.867 [Thread-18] TRACE o.c.frontend.dokany.ReadWriteAdapter - Try to open / as Directory.
10:57:34.870 [Thread-18] TRACE o.c.frontend.dokany.ReadWriteAdapter - (2) / opened successful with handle 2.
10:57:34.870 [Thread-18] TRACE o.c.f.dokany.locks.DataWLockImpl - Released write data lock for ''
10:57:34.870 [Thread-18] TRACE o.c.f.dokany.locks.PathWLockImpl - Released write path lock for ''
10:57:34.875 [Thread-19] TRACE o.c.frontend.dokany.ReadWriteAdapter - zwCreateFile() is called for / with CreationDisposition OPEN_EXISTING.
10:57:34.876 [Thread-19] TRACE o.c.f.dokany.locks.PathWLockImpl - Acquired write path lock for ''
10:57:34.876 [Thread-19] TRACE o.c.f.dokany.locks.DataWLockImpl - Acquired write data lock for ''
10:57:34.877 [Thread-19] TRACE o.c.frontend.dokany.ReadWriteAdapter - Try to open / as Directory.
10:57:34.879 [Thread-19] TRACE o.c.frontend.dokany.ReadWriteAdapter - (3) / opened successful with handle 3.
10:57:34.879 [Thread-19] TRACE o.c.f.dokany.locks.DataWLockImpl - Released write data lock for ''
10:57:34.879 [Thread-19] TRACE o.c.f.dokany.locks.PathWLockImpl - Released write path lock for ''
10:57:34.882 [Thread-20] TRACE o.c.frontend.dokany.ReadWriteAdapter - zwCreateFile() is called for / with CreationDisposition OPEN_EXISTING.
10:57:34.883 [Thread-20] TRACE o.c.f.dokany.locks.PathWLockImpl - Acquired write path lock for ''
10:57:34.883 [Thread-20] TRACE o.c.f.dokany.locks.DataWLockImpl - Acquired write data lock for ''
10:57:34.884 [Thread-20] TRACE o.c.frontend.dokany.ReadWriteAdapter - Try to open / as Directory.
10:57:34.886 [Thread-20] TRACE o.c.frontend.dokany.ReadWriteAdapter - (4) / opened successful with handle 4.
10:57:34.897 [Thread-20] TRACE o.c.f.dokany.locks.DataWLockImpl - Released write data lock for ''
10:57:34.897 [Thread-20] TRACE o.c.f.dokany.locks.PathWLockImpl - Released write path lock for ''
10:57:34.898 [Thread-21] TRACE o.c.frontend.dokany.ReadWriteAdapter - (1) closeFile() is called for /.
10:57:34.902 [Thread-24] TRACE o.c.frontend.dokany.ReadWriteAdapter - (3) getFileInformation() is called for /.
10:57:34.902 [Thread-24] TRACE o.c.f.dokany.locks.PathRLockImpl - Acquired read path lock for ''
10:57:34.902 [Thread-24] TRACE o.c.f.dokany.locks.DataRLockImpl - Acquired read data lock for ''
10:57:34.904 [Thread-24] TRACE o.c.frontend.dokany.ReadWriteAdapter - (3) File Information successful read from /.
10:57:34.904 [Thread-24] TRACE o.c.f.dokany.locks.DataRLockImpl - Released read data lock for ''
10:57:34.904 [Thread-24] TRACE o.c.f.dokany.locks.PathRLockImpl - Released read path lock for ''
10:57:34.906 [Thread-25] TRACE o.c.frontend.dokany.ReadWriteAdapter - (4) getFileInformation() is called for /.
10:57:34.906 [Thread-25] TRACE o.c.f.dokany.locks.PathRLockImpl - Acquired read path lock for ''
10:57:34.906 [Thread-25] TRACE o.c.f.dokany.locks.DataRLockImpl - Acquired read data lock for ''
10:57:34.908 [Thread-25] TRACE o.c.frontend.dokany.ReadWriteAdapter - (4) File Information successful read from /.
10:57:34.908 [Thread-25] TRACE o.c.f.dokany.locks.DataRLockImpl - Released read data lock for ''
10:57:34.908 [Thread-25] TRACE o.c.f.dokany.locks.PathRLockImpl - Released read path lock for ''
10:57:34.911 [Thread-28] TRACE o.c.frontend.dokany.ReadWriteAdapter - (3) cleanup() is called for /.
10:57:47.987 [Background Thread 2] DEBUG o.cryptomator.frontend.dokany.Mount - Unmounting drive P:\: ...
10:57:47.987 [Background Thread 2] INFO com.dokany.java.DokanyDriver - Unmount and shutdown: P:\
10:57:49.793 [JavaFX Application Thread] INFO o.c.k.WindowsProtectedKeychainAccess - Creating new keychain at path f:\Users\max.mueller\AppData\Roaming\Cryptomator\keychain.json
10:57:50.854 [Background Thread 3] TRACE o.c.frontend.dokany.ReadWriteAdapter - unmounted() is called.
10:57:51.856 [Background Thread 2] DEBUG o.cryptomator.frontend.dokany.Mount - Unmounted drive P:\: successfully.
10:57:51.859 [Background Thread 5] DEBUG o.cryptomator.frontend.dokany.Mount - Unmounting drive P:\: ...
10:57:51.859 [Background Thread 5] INFO com.dokany.java.DokanyDriver - Unmount and shutdown: P:\
10:57:51.860 [Background Thread 5] DEBUG o.cryptomator.frontend.dokany.Mount - Unmounted drive P:\: successfully.
10:57:51.860 [Background Thread 4] DEBUG o.cryptomator.frontend.dokany.Mount - Unmounting drive P:\: ...
10:57:51.860 [Background Thread 4] INFO com.dokany.java.DokanyDriver - Unmount and shutdown: P:\
10:57:51.860 [Background Thread 4] DEBUG o.cryptomator.frontend.dokany.Mount - Unmounted drive P:\: successfully.
10:57:51.863 [JavaFX Application Thread] TRACE o.c.u.controllers.UnlockedController - Regular unmount succeeded.
10:57:51.887 [JavaFX Application Thread] INFO o.c.k.WindowsProtectedKeychainAccess - Creating new keychain at path f:\Users\max.mueller\AppData\Roaming\Cryptomator\keychain.json
10:57:51.895 [JavaFX Application Thread] TRACE o.c.u.controllers.UnlockedController - Regular unmount succeeded.
10:57:51.929 [JavaFX Application Thread] INFO o.c.k.WindowsProtectedKeychainAccess - Creating new keychain at path f:\Users\max.mueller\AppData\Roaming\Cryptomator\keychain.json
10:57:51.937 [JavaFX Application Thread] TRACE o.c.u.controllers.UnlockedController - Regular unmount succeeded.
10:57:51.956 [JavaFX Application Thread] INFO o.c.k.WindowsProtectedKeychainAccess - Creating new keychain at path f:\Users\max.mueller\AppData\Roaming\Cryptomator\keychain.json
10:57:56.752 [pool-3-thread-1] INFO o.c.common.settings.SettingsProvider - Settings saved to f:\Users\max.mueller\AppData\Roaming\Cryptomator\settings.json
10:58:03.643 [Background Thread 4] INFO com.dokany.java.DokanyDriver - Dokany version: 100
10:58:03.643 [Background Thread 4] INFO com.dokany.java.DokanyDriver - Dokany driver version: 400
10:58:03.643 [Background Thread 4] DEBUG o.c.frontend.dokany.MountFactory - Mounting on B:\: ...
10:58:03.705 [Background Thread 5] TRACE o.c.frontend.dokany.ReadWriteAdapter - mounted() is called.
10:58:04.232 [Thread-33] TRACE o.c.frontend.dokany.ReadWriteAdapter - zwCreateFile() is called for / with CreationDisposition OPEN_EXISTING.
10:58:04.234 [Thread-33] TRACE o.c.f.dokany.locks.LockManager - Creating ReadWriteLock for
10:58:04.234 [Thread-33] TRACE o.c.f.dokany.locks.PathWLockImpl - Acquired write path lock for ''
10:58:04.234 [Thread-33] TRACE o.c.f.dokany.locks.DataWLockImpl - Acquired write data lock for ''
10:58:04.234 [Thread-33] TRACE o.c.frontend.dokany.ReadWriteAdapter - Try to open / as Directory.
10:58:04.237 [Thread-33] TRACE o.c.frontend.dokany.ReadWriteAdapter - (1) / opened successful with handle 1.
10:58:04.237 [Thread-33] TRACE o.c.f.dokany.locks.DataWLockImpl - Released write data lock for ''
10:58:04.237 [Thread-33] TRACE o.c.f.dokany.locks.PathWLockImpl - Released write path lock for ''
10:58:04.238 [Thread-34] TRACE o.c.frontend.dokany.ReadWriteAdapter - zwCreateFile() is called for / with CreationDisposition OPEN_EXISTING.
10:58:04.240 [Thread-34] TRACE o.c.f.dokany.locks.PathWLockImpl - Acquired write path lock for ''
10:58:04.240 [Thread-34] TRACE o.c.f.dokany.locks.DataWLockImpl - Acquired write data lock for ''
10:58:04.240 [Thread-34] TRACE o.c.frontend.dokany.ReadWriteAdapter - Try to open / as Directory.
10:58:04.243 [Thread-34] TRACE o.c.frontend.dokany.ReadWriteAdapter - (2) / opened successful with handle 2.
10:58:04.243 [Thread-34] TRACE o.c.f.dokany.locks.DataWLockImpl - Released write data lock for ''
10:58:04.243 [Thread-34] TRACE o.c.f.dokany.locks.PathWLockImpl - Released write path lock for ''
10:58:04.244 [Thread-35] TRACE o.c.frontend.dokany.ReadWriteAdapter - zwCreateFile() is called for / with CreationDisposition OPEN_EXISTING.
10:58:04.246 [Thread-35] TRACE o.c.f.dokany.locks.PathWLockImpl - Acquired write path lock for ''
10:58:04.246 [Thread-35] TRACE o.c.f.dokany.locks.DataWLockImpl - Acquired write data lock for ''
10:58:04.246 [Thread-35] TRACE o.c.frontend.dokany.ReadWriteAdapter - Try to open / as Directory.
10:58:04.248 [Thread-35] TRACE o.c.frontend.dokany.ReadWriteAdapter - (3) / opened successful with handle 3.
10:58:04.249 [Thread-35] TRACE o.c.f.dokany.locks.DataWLockImpl - Released write data lock for ''
10:58:04.249 [Thread-35] TRACE o.c.f.dokany.locks.PathWLockImpl - Released write path lock for ''
10:58:04.250 [Thread-36] TRACE o.c.frontend.dokany.ReadWriteAdapter - (1) getFileInformation() is called for /.
10:58:04.251 [Thread-36] TRACE o.c.f.dokany.locks.PathRLockImpl - Acquired read path lock for ''
10:58:04.251 [Thread-36] TRACE o.c.f.dokany.locks.DataRLockImpl - Acquired read data lock for ''
10:58:04.252 [Thread-36] TRACE o.c.frontend.dokany.ReadWriteAdapter - (1) File Information successful read from /.
10:58:04.253 [Thread-36] TRACE o.c.f.dokany.locks.DataRLockImpl - Released read data lock for ''
10:58:04.253 [Thread-36] TRACE o.c.f.dokany.locks.PathRLockImpl - Released read path lock for ''
10:58:04.255 [Thread-37] TRACE o.c.frontend.dokany.ReadWriteAdapter - (2) getFileInformation() is called for /.
10:58:04.255 [Thread-37] TRACE o.c.f.dokany.locks.PathRLockImpl - Acquired read path lock for ''
10:58:04.255 [Thread-37] TRACE o.c.f.dokany.locks.DataRLockImpl - Acquired read data lock for ''
10:58:04.257 [Thread-37] TRACE o.c.frontend.dokany.ReadWriteAdapter - (2) File Information successful read from /.
10:58:04.257 [Thread-37] TRACE o.c.f.dokany.locks.DataRLockImpl - Released read data lock for ''
10:58:04.257 [Thread-37] TRACE o.c.f.dokany.locks.PathRLockImpl - Released read path lock for ''
10:58:04.258 [Thread-38] TRACE o.c.frontend.dokany.ReadWriteAdapter - (3) getFileInformation() is called for /.
10:58:04.259 [Thread-38] TRACE o.c.f.dokany.locks.PathRLockImpl - Acquired read path lock for ''
10:58:04.259 [Thread-38] TRACE o.c.f.dokany.locks.DataRLockImpl - Acquired read data lock for ''
10:58:04.319 [Thread-38] TRACE o.c.frontend.dokany.ReadWriteAdapter - (3) File Information successful read from /.
10:58:04.319 [Thread-38] TRACE o.c.f.dokany.locks.DataRLockImpl - Released read data lock for ''
10:58:04.319 [Thread-38] TRACE o.c.f.dokany.locks.PathRLockImpl - Released read path lock for ''
10:58:04.321 [Thread-39] TRACE o.c.frontend.dokany.ReadWriteAdapter - (1) getFileInformation() is called for /.
10:58:04.321 [Thread-39] TRACE o.c.f.dokany.locks.PathRLockImpl - Acquired read path lock for ''
10:58:04.321 [Thread-39] TRACE o.c.f.dokany.locks.DataRLockImpl - Acquired read data lock for ''
10:58:04.322 [Thread-39] TRACE o.c.frontend.dokany.ReadWriteAdapter - (1) File Information successful read from /.
10:58:04.322 [Thread-39] TRACE o.c.f.dokany.locks.DataRLockImpl - Released read data lock for ''
10:58:04.322 [Thread-39] TRACE o.c.f.dokany.locks.PathRLockImpl - Released read path lock for ''
10:58:04.324 [Thread-40] TRACE o.c.frontend.dokany.ReadWriteAdapter - (2) getFileInformation() is called for /.
10:58:04.324 [Thread-40] TRACE o.c.f.dokany.locks.PathRLockImpl - Acquired read path lock for ''
10:58:04.324 [Thread-40] TRACE o.c.f.dokany.locks.DataRLockImpl - Acquired read data lock for ''
10:58:04.325 [Thread-40] TRACE o.c.frontend.dokany.ReadWriteAdapter - (2) File Information successful read from /.
10:58:04.326 [Thread-40] TRACE o.c.f.dokany.locks.DataRLockImpl - Released read data lock for ''
10:58:04.326 [Thread-40] TRACE o.c.f.dokany.locks.PathRLockImpl - Released read path lock for ''
10:58:04.327 [Thread-41] TRACE o.c.frontend.dokany.ReadWriteAdapter - (3) getFileInformation() is called for /.
10:58:04.328 [Thread-41] TRACE o.c.f.dokany.locks.PathRLockImpl - Acquired read path lock for ''
10:58:04.328 [Thread-41] TRACE o.c.f.dokany.locks.DataRLockImpl - Acquired read data lock for ''
10:58:04.329 [Thread-41] TRACE o.c.frontend.dokany.ReadWriteAdapter - (3) File Information successful read from /.
10:58:04.329 [Thread-41] TRACE o.c.f.dokany.locks.DataRLockImpl - Released read data lock for ''
10:58:04.329 [Thread-41] TRACE o.c.f.dokany.locks.PathRLockImpl - Released read path lock for ''
10:58:04.332 [Thread-43] TRACE o.c.frontend.dokany.ReadWriteAdapter - (2) getFileInformation() is called for /.
10:58:04.332 [Thread-43] TRACE o.c.f.dokany.locks.PathRLockImpl - Acquired read path lock for ''
10:58:04.332 [Thread-43] TRACE o.c.f.dokany.locks.DataRLockImpl - Acquired read data lock for ''
10:58:04.333 [Thread-43] TRACE o.c.frontend.dokany.ReadWriteAdapter - (2) File Information successful read from /.
10:58:04.334 [Thread-43] TRACE o.c.f.dokany.locks.DataRLockImpl - Released read data lock for ''
10:58:04.334 [Thread-43] TRACE o.c.f.dokany.locks.PathRLockImpl - Released read path lock for ''
10:58:04.335 [Thread-44] TRACE o.c.frontend.dokany.ReadWriteAdapter - (3) getFileInformation() is called for /.
10:58:04.335 [Thread-44] TRACE o.c.f.dokany.locks.PathRLockImpl - Acquired read path lock for ''
10:58:04.336 [Thread-44] TRACE o.c.f.dokany.locks.DataRLockImpl - Acquired read data lock for ''
10:58:04.337 [Thread-44] TRACE o.c.frontend.dokany.ReadWriteAdapter - (3) File Information successful read from /.
10:58:04.337 [Thread-44] TRACE o.c.f.dokany.locks.DataRLockImpl - Released read data lock for ''
10:58:04.337 [Thread-44] TRACE o.c.f.dokany.locks.PathRLockImpl - Released read path lock for ''
10:58:04.339 [Thread-46] TRACE o.c.frontend.dokany.ReadWriteAdapter - (2) cleanup() is called for /.
10:58:06.645 [Background Thread 4] TRACE o.cryptomator.frontend.dokany.Mount - Mounting still in progress.
10:58:06.645 [Background Thread 4] DEBUG o.c.frontend.dokany.MountFactory - Mounted directory at B:\ successfully.
10:58:10.918 [JavaFX Application Thread] INFO o.c.k.WindowsProtectedKeychainAccess - Creating new keychain at path f:\Users\max.mueller\AppData\Roaming\Cryptomator\keychain.json
10:58:11.707 [JavaFX Application Thread] ERROR o.c.u.controllers.UnlockedController - Reveal failed.
I believe that we have to look into Dokany’s logfile. Does anyone know where to find it?
Regards
