1.19.1 Installation blocked
I’m having the following message from Norton. Can we make the code better or is there an impact to keep this file blocked? Ofcourse, I downloaded from the same website.
Details
Threat name: IDP.Generic
Threat type: Miscellaneous - This is an app that you may have unknowingly installed and that may harm your computer performance.
Status: Threat detected
Detected by: Behavioral Protection
On PC from: 3/12/26, 2:23 PM
Last Used: 3/14/26, 10:06 AM
Startup Item: No
Unknown
It is unknown how many users in the Norton Community have used this file.
Very new
This file was released a day ago.
High
The file risk is high.
Activity
Path | Type | Status
C:\Program Files\Cryptomator\disableUserConfig.ps1 | File | Infected with IDP.Generic
C:\Windows\System32\WindowsPowerShell\v1.0\powershell.exe | Process | Infected with IDP.Generic
I confirm, same alert with Norton during the installation. I also downloaded the software from the site having taken care to check the fingerprint of the file.
Best regards.
Probably best to add an exception in Norton. Either that or temporarily disable during install.
Thank you for your reports. Those are false positives. The reported files are safe and part of the installer. If you are unsure if you downloaded the official installer, you can always verify it.
You can support Cryptomator by uploading the installer or the blocked scripts to the Norton review program: Submit a file or URL to Norton for review Submit a file or URL to Norton for review
Same just happend with 1.19.2 and Bitdefender (while 1.19.1 gave no warnings and installed).
Funny enough: looking for the protocol of “malicious” scripts, BD found nothing, not even created a protocol entry and the install went flawless.
