I can’t connect to an existing vault on pCloud using Cryptomator 1.5. 0 beta4 on Android. I can reach the list of folders and files on the PCloud server. But when I try to open the vault folder to select the masterkey file Cryptomator doesn’t open the folder and just returns me to the cloud service page. Any ideas what may be causing this?
Thanks for your feedback.
We run into a problem in our “digest access authentication” lib: https://github.com/rburgst/okhttp-digest/issues/59
We fixed this problem and we’ll provide the update ASAP.
Thanks for the reply. Glad to report that problem now solved in latest version (1.5.1}
