i want use cryptomator for myself. In case of emergency i want, that a friend can access my data and use cryptomator from his hardware.
Is this possibke and when yes, how?
Thanks for support
Templeton
Thanks for support
Templeton
It is if you give him the password for the vault and access to your online storage.
ok, sounds easy, thanks for your answer
Well you’re giving someone else full access to your files. Please keep that in mind.
