I have a vault that I am able to unlock but navigating around the vault is very slow. It is worse with folders that have jpg files. For example, just to open a single jpg file can take 30-40 seconds. When I display the folder content with the option to show small images which has 2500+ pics it is never finishes as you can see it is working on each one individually taking just short of a minute for each one. I also tried opening a backup vault of the same and I am experiencing the same.
I am trying to copy the folder to my SSD to see if I can get to the picture I need. As I am copying the folder Cryptomator shows a large amount of green bars like it is unencrypting each file as it copies? I thought the files were unecrypted when you open the vault and you can see the file names? At that point it is just like seeing a file in windows explorer and you can navigate around. It has the same behavior in the copy as when I try to scroll down the pictures it is having to unecrypt each file in view which is taking an extremely long time.
I have not seen this before. Should I try uninstall Cryptomator and reinstall? I am on v1.4
