I installed the Cryptomator version today (from 1.4.14 to 1.4.15), after that, a vault upgrade was neccessary. i put in my password, confirming my sync is done, but i can’t pass the “vault upgrade” screen. no warning shown. now i can’t open my files. any help?
crawling through the logfiles, i found this:
Cryptomator0.log:
17:57:48.670 [main] INFO org.cryptomator.launcher.Cryptomator - Starting Cryptomator 1.4.15 on Windows 10 10.0 (amd64)
17:57:48.673 [main] DEBUG org.cryptomator.logging.DebugMode - Debug mode enabled
17:57:48.674 [main] DEBUG org.cryptomator.launcher.IpcFactory - **[Client] Failed to connect.**
17:57:48.975 [main] DEBUG org.cryptomator.launcher.IpcFactory - [Server] Wrote IPC port 12828 to C:\Users\dee1337\AppData\Roaming\Cryptomator\ipcPort.bin
17:57:48.976 [main] INFO o.c.launcher.IpcProtocolImpl - Received launch args:
17:57:48.978 [main] DEBUG org.cryptomator.launcher.Cryptomator - Did not find running application instance. Launching GUI...
17:57:49.529 [JavaFX Application Thread] INFO org.cryptomator.launcher.Cryptomator - JavaFX application started.
17:57:49.548 [JavaFX Application Thread] DEBUG org.cryptomator.ui.l10n.Localization - Loaded localization default file: /localization/en.txt
17:57:49.548 [JavaFX Application Thread] DEBUG org.cryptomator.ui.l10n.Localization - Detected language "de" and region "DE"
17:57:49.550 [JavaFX Application Thread] TRACE org.cryptomator.ui.l10n.Localization - Attempting to load localization from: /localization/de_DE.txt
17:57:49.550 [JavaFX Application Thread] TRACE org.cryptomator.ui.l10n.Localization - Attempting to load localization from: /localization/de.txt
17:57:49.639 [JavaFX Application Thread] INFO org.cryptomator.jni.JniModule - loaded WinFunctions.dll
17:57:49.673 [JavaFX Application Thread] INFO o.c.ui.controllers.MainController - Unable to setPreferencesHandler, probably not supported on this OS.
17:57:50.809 [JavaFX Application Thread] INFO o.c.ui.controllers.WelcomeController - Current version: 1.4.15, lastest version: 1.4.15
17:58:21.603 [JavaFX Application Thread] ERROR org.cryptomator.ui.util.Tasks - Unhandled exception
org.cryptomator.cryptolib.api.AuthenticationFailedException: Header MAC doesn't match.
at org.cryptomator.cryptolib.v1.FileHeaderCryptorImpl.decryptHeader(FileHeaderCryptorImpl.java:113)
at org.cryptomator.ui.model.upgrade.UpgradeVersion4to5.migrate(UpgradeVersion4to5.java:111)
at org.cryptomator.ui.model.upgrade.UpgradeVersion4to5$1.visitFile(UpgradeVersion4to5.java:87)
at org.cryptomator.ui.model.upgrade.UpgradeVersion4to5$1.visitFile(UpgradeVersion4to5.java:65)
at java.base/java.nio.file.Files.walkFileTree(Files.java:2724)
at org.cryptomator.ui.model.upgrade.UpgradeVersion4to5.upgrade(UpgradeVersion4to5.java:65)
at org.cryptomator.ui.model.upgrade.UpgradeStrategy.upgrade(UpgradeStrategy.java:74)
at org.cryptomator.ui.controllers.UpgradeController.lambda$upgrade$0(UpgradeController.java:128)
let me paste a part of upgrade.log, too:
17:58:18.435 [Background Thread 2] INFO o.c.ui.model.upgrade.UpgradeStrategy - Upgrading E:\GDRIVE\[ VERSCHLUESSELT ]\Verschluesselt from 4 to 5.
17:58:18.598 [Background Thread 2] INFO o.c.ui.model.upgrade.UpgradeStrategy - Backuped masterkey.
17:58:18.599 [Background Thread 2] INFO o.c.u.m.upgrade.UpgradeVersion4to5 - Starting migration of E:\GDRIVE\[ VERSCHLUESSELT ]\Verschluesselt\d\22\2J5MUUMSDI5ZJEPIR4GS7RVGNMHMR5\7DJE3HYLXWNFZCT4SFYFDHDWW6CGS4RK5F4KHGCM7ZCQ3AWU...
17:58:18.600 [Background Thread 2] INFO o.c.u.m.upgrade.UpgradeVersion4to5 - Header read
17:58:18.602 [Background Thread 2] INFO o.c.u.m.upgrade.UpgradeVersion4to5 - Skipping already migrated file
last entries (tail):
17:58:21.599 [Background Thread 2] INFO o.c.u.m.upgrade.UpgradeVersion4to5 - Starting migration of E:\GDRIVE\[ VERSCHLUESSELT ]\Verschluesselt\d\EE\EQBHG4ZBK4CP24QQBUES5COBJU7AVS\WGG2WNO6FZBSQZO7576PAKOMGWCUJCL47D4JQS7PTZW2SW3ZXHF2QTUPP63KQLIX...
17:58:21.599 [Background Thread 2] INFO o.c.u.m.upgrade.UpgradeVersion4to5 - Header read
17:58:21.599 [Background Thread 2] INFO o.c.u.m.upgrade.UpgradeVersion4to5 - Skipping already migrated file
17:58:21.599 [Background Thread 2] INFO o.c.u.m.upgrade.UpgradeVersion4to5 - Starting migration of E:\GDRIVE\[ VERSCHLUESSELT ]\Verschluesselt\d\EE\EQBHG4ZBK4CP24QQBUES5COBJU7AVS\WSGV44HTOLYVFE5WKVHU2DOOMIPWG43GKAIX7RBLUVLYAEG7HLGIMI26J4DU7UKIRY4QU===...
17:58:21.600 [Background Thread 2] INFO o.c.u.m.upgrade.UpgradeVersion4to5 - Header read
