Hello
First of all many thank for maintaining Cryptomator – truly great piece of software!
Hope that I am posting in the right place. I recently updated to 1.5.6 and Cryptomator prompted me to upgrade the vault to the new format. I successfully migrated 2 vaults but for 3 other vaults I am getting the exact same error, below. I tried running multiple times to no avail. Is there anything else which I can try to debug?
java.nio.file.FileSystemException: [removed for privacy]: Operation timed out
at java.base/sun.nio.fs.UnixException.asIOException(Unknown Source)
at java.base/sun.nio.fs.UnixDirectoryStream$UnixDirectoryIterator.readNextEntry(Unknown Source)
at java.base/sun.nio.fs.UnixDirectoryStream$UnixDirectoryIterator.hasNext(Unknown Source)
at java.base/java.nio.file.FileTreeWalker.next(Unknown Source)
at java.base/java.nio.file.Files.walkFileTree(Unknown Source)
at org.cryptomator.cryptofs.migration.v7.Version7Migrator.migrate(Version7Migrator.java:82)
at org.cryptomator.cryptofs.migration.Migrators.migrate(Migrators.java:112)
at org.cryptomator.ui.migration.MigrationRunController.lambda$migrate$2(MigrationRunController.java:115)
at org.cryptomator.ui.common.Tasks$TaskImpl.call(Tasks.java:139)
I also am getting the same errors now today after I tried to migrate from version 6 to 7. Did you ever figure this out? Was using WebDAV but switched to Fuse and trying again.
Blockquotejava.nio.file.FileSystemException: /Volumes/dav/SS1/d/UR/U7T4YOATV2CVD5CTLOP5WA3K4SCCZP/5SL7DZCE6KSLLSNLNQ35UHSOGMX3LZ5GPEDXMOJZIUFMK=== → /Volumes/dav/SS1/d/UR/U7T4YOATV2CVD5CTLOP5WA3K4SCCZP/7Jfx5ETypLXJq2w32h5OMy-156Z5B3Y5OUUKxQ==.c9r: Operation timed out
at java.base/sun.nio.fs.UnixCopyFile.move(Unknown Source)
at java.base/sun.nio.fs.UnixFileSystemProvider.move(Unknown Source)
at java.base/java.nio.file.Files.move(Unknown Source)
at org.cryptomator.cryptofs.migration.v7.FilePathMigration.migrate(FilePathMigration.java:139)
at org.cryptomator.cryptofs.migration.v7.MigratingVisitor.postVisitDirectory(MigratingVisitor.java:55)
at org.cryptomator.cryptofs.migration.v7.MigratingVisitor.postVisitDirectory(MigratingVisitor.java:17)
at org.cryptomator.cryptofs.migration.v7.Version7Migrator.migrateFileNames(Version7Migrator.java:116)
at org.cryptomator.cryptofs.migration.v7.Version7Migrator.migrate(Version7Migrator.java:98)
at org.cryptomator.ui.migration.MigrationRunController.lambda$migrate$2(MigrationRunController.java:117)
at org.cryptomator.ui.common.Tasks$TaskImpl.call(Tasks.java:140)
