Hi all,
I’m hoping someone can help.
I’ve just updated to Cryptomator 1.19.2 on my Mac (running Tahoe 26.4.1). During the update, it mentioned a change in file locations, which didn’t seem like a big issue since I still have all my files.
However, when I unlock/decrypt my vault, it appears empty. I haven’t made any major changes to my Mac, and all my encrypted Cryptomator files are still there.
I should add that I’m seeing this error referenced here: Error 91OE:Q3PE:8MFL · cryptomator/cryptomator · Discussion #3969 · GitHub . My vault is stored on iCloud.
The symptoms are:
I navigate to the correct vault folder
Enter my password
Then I get the error mentioned in the GitHub post, and the vault shows as empty
Also worth noting: I can access and decrypt my files on my iPhone via iCloud with no issues, so the data itself seems intact.
Does anyone know what I might be missing or what could have caused this?
Thanks in advance.
Just to update on this (4th May 2026)
I’ve been looking further into this and wanted to share some additional findings.
I understand that using FUSE on macOS is also recommended, and I will consider this, but my setup has been working fine without it up until now.
From what I can tell, my setup is valid, but it depends on three layers all behaving nicely:
Cryptomator
macOS (Tahoe 26.4.1 in my case)
iCloud file handling
It seems like one of these has changed, most likely iCloud’s file streaming or macOS filesystem behaviour.
Additional details from my testing:
I can confirm the vault works perfectly when copied locally to my desktop on macOS
I can also access and decrypt all files on my iPhone via iCloud with no issues
The encrypted files are definitely present in the vault (I can see them in Finder)
This seems to point to an issue with iCloud/macOS rather than the vault itself.
When opening the vault directly from iCloud on my Mac, it appears empty and I see repeated errors in the logs:
PROPFIND request failed, returning 500. Reason: java.io.UncheckedIOException
From testing, this looks like it may be related to how iCloud is handling file availability (possibly not fully downloaded) or a WebDAV mount issue introduced in recent versions (Cryptomator 1.19.2 or macOS Tahoe 26.4.1).
So far:
Local copy of the vault > works
iCloud-hosted vault on Mac > shows empty + errors
iPhone via iCloud > works
Has anyone else seen this behaviour recently, or found a reliable fix?
Thanks again for any help.
