Thank you. So there are numerous logs cryptomator.log , cryptomator0.log, cryptomator1.log…
So I just opened cryptomator.log :
16:16:20.932 [main] INFO org.cryptomator.launcher.Cryptomator - Starting Cryptomator 1.4.4 on Linux 4.15.0-45-generic (amd64)
16:16:21.287 [main] INFO o.c.launcher.FileOpenRequestHandler - Unable to setOpenFileHandler, probably not supported on this OS.
16:16:21.648 [JavaFX Application Thread] INFO o.c.launcher.MainApplication - JavaFX application started.
16:16:21.723 [JavaFX Application Thread] INFO o.c.common.settings.SettingsProvider - Settings loaded from /home/arnauld/.Cryptomator/settings.json
16:16:21.917 [JavaFX Application Thread] INFO o.c.ui.controllers.MainController - Unable to setPreferencesHandler, probably not supported on this OS.
16:16:22.856 [JavaFX Application Thread] INFO o.c.ui.controllers.WelcomeController - Current version: 1.4.4, lastest version: 1.4.5
16:16:33.474 [Background Thread 2] ERROR org.cryptomator.ui.model.FuseVolume - Failed to create mount path at /home/arnauld/.Cryptomator/dXv62-sOSQCR_x. Giving up after 10 attempts.
16:16:33.492 [JavaFX Application Thread] ERROR o.c.ui.controllers.UnlockController - Unlock failed for technical reasons.
java.nio.file.FileAlreadyExistsException: /home/arnauld/.Cryptomator/dXv62-sOSQCR
at org.cryptomator.ui.model.FuseVolume.createTemporaryMountPoint(FuseVolume.java:86)
at org.cryptomator.ui.model.FuseVolume.mount(FuseVolume.java:55)
at org.cryptomator.ui.model.Vault.unlock(Vault.java:117)
at org.cryptomator.ui.controllers.UnlockController.lambda$didClickUnlockButton$0(UnlockController.java:439)
16:16:35.067 [JavaFX Application Thread] INFO o.c.launcher.MainApplication - JavaFX application stopped.
16:16:35.071 [Thread-0] INFO o.c.launcher.CleanShutdownPerformer - Goodbye.
And when using version 1.4.5:
16:22:52.508 [main] INFO org.cryptomator.launcher.Cryptomator - Starting Cryptomator 1.4.5 on Linux 4.15.0-45-generic (amd64)
16:22:52.847 [main] INFO o.c.launcher.FileOpenRequestHandler - Unable to setOpenFileHandler, probably not supported on this OS.
16:22:53.230 [JavaFX Application Thread] INFO o.c.launcher.MainApplication - JavaFX application started.
16:22:53.303 [JavaFX Application Thread] INFO o.c.common.settings.SettingsProvider - Settings loaded from /home/arnauld/.Cryptomator/settings.json
16:22:53.499 [JavaFX Application Thread] INFO o.c.ui.controllers.MainController - Unable to setPreferencesHandler, probably not supported on this OS.
16:22:54.516 [JavaFX Application Thread] INFO o.c.ui.controllers.WelcomeController - Current version: 1.4.5, lastest version: 1.4.5
16:23:04.232 [Background Thread 2] ERROR org.cryptomator.ui.model.FuseVolume - Failed to create mount path at /home/arnauld/.Cryptomator/dXv62-sOSQCR_x. Giving up after 10 attempts.
16:23:04.242 [JavaFX Application Thread] ERROR o.c.ui.controllers.UnlockController - Unlock failed for technical reasons.
