Hello, everyone,
I installed Cryptomator on my desktop PC. There it runs with Pcloud. Now I wanted to install it on my Lappi. Setting up safe works. But when I try to unlock it, I get an error message:
org.cryptomator.cryptolib.api.UnsupportedVaultFormatException: Tried to open vault of version 999, but can only handle version 7
at org.cryptomator.cryptolib.v1.CryptorProviderImpl.createFromKeyFile(CryptorProviderImpl.java:118)
at org.cryptomator.cryptolib.v1.CryptorProviderImpl.createFromKeyFile(CryptorProviderImpl.java:109)
at org.cryptomator.cryptolib.v1.CryptorProviderImpl.createFromKeyFile(CryptorProviderImpl.java:40)
at org.cryptomator.cryptofs.CryptoFileSystemModule.provideCryptor(CryptoFileSystemModule.java:41)
at org.cryptomator.cryptofs.CryptoFileSystemModule_ProvideCryptorFactory.provideCryptor(CryptoFileSystemModule_ProvideCryptorFactory.java:56)
at org.cryptomator.cryptofs.CryptoFileSystemModule_ProvideCryptorFactory.get(CryptoFileSystemModule_ProvideCryptorFactory.java:43)
at org.cryptomator.cryptofs.DaggerCryptoFileSystemProviderComponent$CryptoFileSystemComponentImpl.cryptoFileSystem(DaggerCryptoFileSystemProviderComponent.java:329)
at org.cryptomator.common.vaults.Vault.createCryptoFileSystem(Vault.java:121)
at org.cryptomator.common.vaults.Vault.unlock(Vault.java:126)
Does somebody has any idea?
