Windows
- Windows 10 Pro 19042.928
- Cryptomator v1.15.16
- four vaults, two local file system, one in Box.net, one in Google Drive
All my vaults fail to open after entering the correct passcode (see error below). All worked properly before the update. I was using the previous version, ran the update, re-started computer, and ran CM and then errors occur.
What I’ve done:
- I’ve uninstalled CM, rebooted, and re-installed CM.
- After reading many other posts, I’ve tried uninstallng, re-installing DOKANY multiple times.
- Tried WEBDAV and it works, but I prefer to use DOKANY due to the size restrictions.
Now, still not being able to access my vaults, I need help…
thank you.
... 11 more
at com.dokany.java.DokanyMount.mount(DokanyMount.java:120)
... 13 more
