Unable to write to existing vault on pcloud (intel mac)
Today i realized i can’t write into exiting vault on pcloud , tried from mac cryptomator client. I testd using ios client, no such issue to the same pcloud vault. initially i thought it’s pcloud mac issue, thus i downgraded to earlier verision 4.1, same issue, wondering if any other user facing similar issue? i can create new vault on pcloud with the cryptmator mac and able to write with no issue. only existing vaults are in read only when accessed from mac cryptomator.
/cryptomator mac 1.19.3 (dmg-6495)
What software, or from whom, are you using to connect and mount a folder to PCloud?
You can use the native pCloud software if it’s available for the Mac, or use pCloud as it also supports WebDAV and you can do:
webdav.pcloud.com
on mac os.yes, i am using native pcloud client, and crytomator mac to open the vault. I have been using this for years … cryptomator mounts the vault via mac-fuse on mac. Not sure why suddenly the opened vault(s), i am unable to write anything onto it.
There’s another person that posted a query for support recently and was also having difficulty writing to a vault that they’ve had for a while, with 50 GB of data in it. Now they can’t write to the vault at all.
Do this test.
Try and create a directory or copy a file into the vault itself, not the mounted vault where the files are decrypted, but in the vault itself. See if you get errors trying to create a new folder for example.
There’s a good possibility you’ll get an error there too.
You can create a brand new vault on your PCloud Drive and confirm that it works normally.
I would say, as a last-ditch worst-case scenario, create the same number of brand-new vaults and relocate your data into the new vaults.
Depending on how much data you have (how many gigabytes), you might want to consider relocating all of your data that you have access to for now to a new vault. You don’t want to find that it goes from read-only to read nothing and has no other options. Do you have a clean backup of all your data files? If not I would do that now. Copy all of your data to an external SSD for now.
And also you mentioned correctly that your iPhone can access the vault, decrypt files, and download them to your phone. Can you also upload files from your phone to the cloud?
It would be very odd and strange if one worked and the other didn’t. It would suggest that there is something specific about your computer installation and software.
Is it possible the IOS client got updated recently?
Try these things first and we’ll see where you are at that point.
newly created vault don’t have this problem, i can write without issue. weird thing is the old vaults were fine (writeable) 2 week ago. i end up spinning up a vps, using rclone to copy all vaults from pcloud to the vps, and delete all files in my pcloud, then copy back all the vaults from the vps to the pcloud. Now all vaults seems to work fine, (writeable) via cryptomator mac. not sure what the issue was though, but at least it’s now working 100%
Here is some information regarding best habits and practices when using PCloud and Cryptomator together.
It’s possible it might help you avoid this problem happening again.
Yes, it is generally safe to shut down or restart a Mac while a Cryptomator vault is unlocked. However, I recommend locking your Cryptomator vaults before shutting down or restarting macOS, especially when the vault is stored on a mounted pCloud drive.
There are two separate concerns: protecting your encrypted data and preventing file corruption.
What happens if you shut down your Mac with a vault open?
When you initiate a normal macOS shutdown or restart:
  • macOS asks running applications to quit.
  • Cryptomator normally has an opportunity to close its virtual drive and release resources.
  • macOS closes the remaining applications and shuts down.
The important distinction is that having a Cryptomator vault unlocked does not itself cause corruption. The greater risk occurs when an application is actively writing data to the vault during shutdown.
For example, if you’re editing a document stored inside your Cryptomator vault and shut down your Mac before the file has finished saving, the document could become incomplete or corrupted.
Special considerations when using pCloud Drive
When using Cryptomator with pCloud Drive mounted as a cloud drive on macOS, there are two layers involved:
  • pCloud Drive: Provides access to files stored remotely in pCloud without requiring you to synchronize the entire drive to your Mac.
  • Cryptomator: Unlocks your encrypted vault and presents its contents as a separate virtual drive.
Even though pCloud Drive is mounted rather than synchronized to a local folder, it may temporarily cache data on your Mac before uploading it to the cloud.
Consequently, when you save a file inside your Cryptomator vault, the operation may involve Cryptomator encrypting the data and pCloud subsequently transferring it to remote storage.
Locking your Cryptomator vault does not necessarily mean pCloud has finished uploading all pending data.
Recommended shutdown procedure for macOS
  • Finish working with your files. Make sure no applications are actively saving documents or copying files into the Cryptomator vault.
  • Close applications accessing the vault. This includes Finder windows or applications with files open inside the vault.
  • Lock the vault in Cryptomator. Open Cryptomator and click Lock for each unlocked vault.
  • Allow pCloud to finish pending operations. Check the pCloud application for any activity or pending uploads.
  • Shut down or restart your Mac normally.
You should lock the Cryptomator vault before disconnecting or unmounting the underlying pCloud Drive.
What if you forget to lock the vault?
If you occasionally shut down your Mac without manually locking the vault, it generally should not cause problems.
Cryptomator is designed to work with mounted virtual drives, and a normal macOS shutdown typically allows applications to terminate gracefully.
However, there is a greater risk of data corruption if:
  • Your Mac loses power unexpectedly.
  • Your internet connection drops during a file operation.
  • pCloud Drive disconnects while Cryptomator is writing data.
  • macOS is forced to shut down while files are being saved.
Bottom line
You do not absolutely have to lock Cryptomator before shutting down your Mac, but doing so is the safer practice.
Because your encrypted vault is stored on a mounted pCloud cloud drive, I particularly recommend locking Cryptomator before shutting down, restarting, or disconnecting pCloud Drive.
This ensures Cryptomator has finished its own file operations and released the vault before macOS terminates the underlying cloud-drive connection.
One final distinction: locking Cryptomator confirms that its virtual drive has been closed, but it does not guarantee that pCloud has completed transferring every encrypted file to its servers.
