I have tried several times to upgrade my vault from 1.4.17 to 1.5.6. The vault is located on a Synology NAS and is approximately 4TB. I have pasted the error log below. I would appreciate help in upgrading this vault because currently I cannot access my data. Thank you.
java.nio.file.DirectoryNotEmptyException: /Volumes/GoogleDriveNJIT/ArchivedDocuments/m
at java.base/sun.nio.fs.UnixFileSystemProvider.implDelete(Unknown Source)
at java.base/sun.nio.fs.AbstractFileSystemProvider.deleteIfExists(Unknown Source)
at java.base/java.nio.file.Files.deleteIfExists(Unknown Source)
at org.cryptomator.cryptofs.common.DeletingFileVisitor.forceDeleteIfExists(DeletingFileVisitor.java:68)
at org.cryptomator.cryptofs.common.DeletingFileVisitor.postVisitDirectory(DeletingFileVisitor.java:57)
at org.cryptomator.cryptofs.common.DeletingFileVisitor.postVisitDirectory(DeletingFileVisitor.java:31)
at java.base/java.nio.file.Files.walkFileTree(Unknown Source)
at org.cryptomator.cryptofs.migration.v7.Version7Migrator.migrate(Version7Migrator.java:105)
at org.cryptomator.cryptofs.migration.Migrators.migrate(Migrators.java:112)
at org.cryptomator.ui.migration.MigrationRunController.lambda$migrate$2(MigrationRunController.java:115)
at org.cryptomator.ui.common.Tasks$TaskImpl.call(Tasks.java:139)
