Since I’ve update to version 1.6.16 (deb-4116), I can’t unlock my vault on Ubuntu 22.10.
This is my log file:
13:01:03.373 [main] INFO o.c.common.settings.SettingsProvider - Settings loaded from /home/pknl/.config/Cryptomator/settings.json
13:01:03.446 [main] INFO org.cryptomator.common.Environment - user.home: /home/pknl
13:01:03.447 [main] INFO org.cryptomator.common.Environment - java.library.path: /usr/java/packages/lib:/usr/lib64:/lib64:/lib:/usr/lib
13:01:03.447 [main] INFO org.cryptomator.common.Environment - user.language: fr
13:01:03.447 [main] INFO org.cryptomator.common.Environment - user.region: null
13:01:03.447 [main] INFO org.cryptomator.common.Environment - logback.configurationFile: null
13:01:03.447 [main] INFO org.cryptomator.common.Environment - cryptomator.settingsPath: ~/.config/Cryptomator/settings.json:~/.Cryptomator/settings.json
13:01:03.447 [main] INFO org.cryptomator.common.Environment - cryptomator.ipcSocketPath: ~/.config/Cryptomator/ipc.socket
13:01:03.448 [main] INFO org.cryptomator.common.Environment - cryptomator.integrationsWin.keychainPaths: null
13:01:03.448 [main] INFO org.cryptomator.common.Environment - cryptomator.logDir: ~/.local/share/Cryptomator/logs
13:01:03.448 [main] INFO org.cryptomator.common.Environment - cryptomator.loopbackAlias: null
13:01:03.449 [main] INFO org.cryptomator.common.Environment - cryptomator.pluginDir: ~/.local/share/Cryptomator/plugins
13:01:03.449 [main] INFO org.cryptomator.common.Environment - cryptomator.mountPointsDir: ~/.local/share/Cryptomator/mnt
13:01:03.449 [main] INFO org.cryptomator.common.Environment - cryptomator.minPwLength: null
13:01:03.449 [main] INFO org.cryptomator.common.Environment - cryptomator.appVersion: 1.6.16
13:01:03.449 [main] INFO org.cryptomator.common.Environment - cryptomator.buildNumber: deb-4116
13:01:03.450 [main] INFO org.cryptomator.common.Environment - cryptomator.showTrayIcon: false
13:01:03.450 [main] INFO org.cryptomator.common.Environment - cryptomator.p12Path: ~/.config/Cryptomator/key.p12
13:01:03.450 [main] INFO o.cryptomator.launcher.Cryptomator - Starting Cryptomator 1.6.16 on Linux 5.19.0-26-generic (amd64)
13:01:03.450 [main] DEBUG org.cryptomator.logging.DebugMode - Debug mode enabled
13:01:03.452 [main] DEBUG o.c.launcher.SupportedLanguages - Using system locale
13:01:03.515 [main] INFO org.cryptomator.ipc.Server - Spawning IPC server listening on socket /home/pknl/.config/Cryptomator/ipc.socket
13:01:04.109 [main] DEBUG o.c.launcher.IpcMessageHandler - Received launch args:
13:01:04.115 [main] DEBUG o.cryptomator.launcher.Cryptomator - Did not find running application instance. Launching GUI…
13:01:04.596 [JavaFX Application Thread] INFO o.cryptomator.launcher.Cryptomator - JavaFX runtime started after 2082ms
13:01:04.613 [JavaFX Application Thread] DEBUG o.c.i.common.ClassLoaderFactory - Found jars in cryptomator.pluginDir:
13:01:05.287 [JavaFX Application Thread] DEBUG o.cryptomator.common.CommonsModule - Starting App Scheduled Executor 01
13:01:05.290 [App Scheduled Executor 01] DEBUG o.cryptomator.common.CommonsModule - Starting App Scheduled Executor 02
13:01:05.297 [JavaFX Application Thread] DEBUG o.c.i.common.ClassLoaderFactory - Found jars in cryptomator.pluginDir:
13:01:05.527 [JavaFX Application Thread] TRACE o.cryptomator.ui.fxapp.FxApplication - FxApplication.start()
13:01:05.789 [JavaFX Application Thread] DEBUG o.cryptomator.common.CommonsModule - Starting App Background Thread 001
13:01:06.762 [JavaFX Application Thread] DEBUG o.c.i.common.ClassLoaderFactory - Found jars in cryptomator.pluginDir:
13:01:06.767 [JavaFX Application Thread] DEBUG o.c.i.common.IntegrationsLoader - TrayMenuController: Found implementation: org.cryptomator.ui.traymenu.AwtTrayMenuController in jar /usr/lib/cryptomator/lib/app/mods/cryptomator-1.7.0-SNAPSHOT.jar
13:01:06.818 [JavaFX Application Thread] DEBUG o.c.i.common.IntegrationsLoader - TrayMenuController: Implementation is available: org.cryptomator.ui.traymenu.AwtTrayMenuController
13:01:07.239 [JavaFX Application Thread] DEBUG o.cryptomator.ui.common.FontLoader - Loaded family: Font Awesome 5 Free Solid
13:01:07.335 [JavaFX Application Thread] TRACE o.c.u.m.MainWindowTitleController - init MainWindowTitleController
13:01:07.405 [JavaFX Application Thread] DEBUG o.c.i.common.ClassLoaderFactory - Found jars in cryptomator.pluginDir:
13:01:07.410 [JavaFX Application Thread] DEBUG o.c.i.common.IntegrationsLoader - KeychainAccessProvider: Found implementation: org.cryptomator.linux.keychain.KDEWalletKeychainAccess in jar /usr/lib/cryptomator/lib/app/mods/integrations-linux-1.1.0.jar
13:01:07.416 [JavaFX Application Thread] DEBUG o.c.i.common.IntegrationsLoader - KeychainAccessProvider: Found implementation: org.cryptomator.linux.keychain.SecretServiceKeychainAccess in jar /usr/lib/cryptomator/lib/app/mods/integrations-linux-1.1.0.jar
13:01:08.343 [JavaFX Application Thread] DEBUG o.c.i.common.IntegrationsLoader - KeychainAccessProvider: Implementation is available: org.cryptomator.linux.keychain.KDEWalletKeychainAccess
13:01:08.351 [JavaFX Application Thread] DEBUG o.c.i.common.IntegrationsLoader - KeychainAccessProvider: Implementation is available: org.cryptomator.linux.keychain.SecretServiceKeychainAccess
13:01:09.088 [JavaFX Application Thread] TRACE o.c.ui.mainwindow.ResizeController - init ResizeController
13:01:09.105 [JavaFX Application Thread] TRACE o.c.u.m.MainWindowController - init MainWindowController
13:01:10.461 [JavaFX Application Thread] DEBUG o.cryptomator.ui.fxapp.FxApplication - Main window initialized after 7947ms
13:01:12.349 [JavaFX Application Thread] DEBUG o.cryptomator.common.CommonsModule - Starting App Background Thread 002
13:01:12.354 [JavaFX Application Thread] DEBUG o.cryptomator.ui.fxapp.UpdateChecker - Checking for updates…
13:01:13.955 [JavaFX Application Thread] DEBUG o.c.common.vaults.VaultStats - stop recording stats
13:01:13.962 [JavaFX Application Thread] DEBUG o.c.ui.fxapp.FxApplicationWindows - Start unlock workflow for Perso
13:01:13.989 [JavaFX Application Thread] DEBUG o.cryptomator.common.CommonsModule - Starting App Background Thread 003
13:01:15.589 [JavaFX Application Thread] INFO o.cryptomator.ui.fxapp.UpdateChecker - Current version: 1.6.16, lastest version: 1.6.15
13:01:21.242 [JavaFX Application Thread] TRACE o.c.u.k.m.PassphraseEntryController - UnlockController.unlock()
13:01:22.367 [App Background Thread 003] DEBUG o.c.cryptofs.common.BackupHelper - Verified backup file: /home/pknl/Dropbox/Perso/masterkey.cryptomator.0A010051.bkup
13:01:22.375 [App Background Thread 003] DEBUG o.c.cryptofs.common.BackupHelper - Verified backup file: /home/pknl/Dropbox/Perso/vault.cryptomator.C9DA1E0C.bkup
13:01:22.488 [App Background Thread 003] DEBUG o.cryptomator.cryptofs.ReadonlyFlag - Vault opened for read and write.
13:01:22.708 [App Background Thread 003] DEBUG o.c.c.mountpoint.MountPointHelper - Performing cleanup of mountpoint dir /home/pknl/.local/share/Cryptomator/mnt.
13:01:22.709 [App Background Thread 003] WARN o.c.c.mountpoint.MountPointHelper - Unable to perform cleanup of mountpoint dir /home/pknl/.local/share/Cryptomator/mnt.
java.io.IOException: Cleanup failed
at org.cryptomator.desktop@1.7.0-SNAPSHOT/org.cryptomator.common.mountpoint.MountPointHelper.clearIrregularUnmountDebris(MountPointHelper.java:67)
at org.cryptomator.desktop@1.7.0-SNAPSHOT/org.cryptomator.common.mountpoint.MountPointHelper.clearIrregularUnmountDebrisIfNeeded(MountPointHelper.java:61)
at org.cryptomator.desktop@1.7.0-SNAPSHOT/org.cryptomator.common.mountpoint.TemporaryMountPointChooser.chooseMountPoint(TemporaryMountPointChooser.java:44)
at org.cryptomator.desktop@1.7.0-SNAPSHOT/org.cryptomator.common.vaults.AbstractVolume.determineMountPoint(AbstractVolume.java:25)
at org.cryptomator.desktop@1.7.0-SNAPSHOT/org.cryptomator.common.vaults.FuseVolume.mount(FuseVolume.java:41)
at org.cryptomator.desktop@1.7.0-SNAPSHOT/org.cryptomator.common.vaults.Vault.unlock(Vault.java:154)
at org.cryptomator.desktop@1.7.0-SNAPSHOT/org.cryptomator.ui.keyloading.KeyLoadingStrategy.use(KeyLoadingStrategy.java:79)
at org.cryptomator.desktop@1.7.0-SNAPSHOT/org.cryptomator.ui.unlock.UnlockWorkflow.attemptUnlock(UnlockWorkflow.java:72)
at org.cryptomator.desktop@1.7.0-SNAPSHOT/org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:62)
at org.cryptomator.desktop@1.7.0-SNAPSHOT/org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:35)
at javafx.graphics@19/javafx.concurrent.Task$TaskCallable.call(Unknown Source)
Suppressed: java.nio.file.FileSystemException: /home/pknl/.local/share/Cryptomator/mnt/Perso: Noeud final de transport n’est pas connecté
at java.base/sun.nio.fs.UnixFileAttributeViews$Basic.readAttributes(Unknown Source)
at java.base/sun.nio.fs.UnixFileSystemProvider.readAttributes(Unknown Source)
at java.base/sun.nio.fs.LinuxFileSystemProvider.readAttributes(Unknown Source)
at java.base/java.nio.file.Files.readAttributes(Unknown Source)
at org.cryptomator.desktop@1.7.0-SNAPSHOT/org.cryptomator.common.mountpoint.MountPointHelper.clearIrregularUnmountDebris(MountPointHelper.java:73)
… 15 common frames omitted
Suppressed: java.nio.file.FileSystemException: /home/pknl/.local/share/Cryptomator/mnt/Perso (1QAhsT1jqCTX): Noeud final de transport n’est pas connecté
Suppressed: java.nio.file.FileSystemException: /home/pknl/.local/share/Cryptomator/mnt/Perso_(1QAhsT1jqCTX)1: Noeud final de transport n’est pas connecté
13:01:22.722 [App Background Thread 003] DEBUG o.c.c.m.TemporaryMountPointChooser - Successfully created mount point: /home/pknl/.local/share/Cryptomator/mnt/Perso(1QAhsT1jqCTX)_2
Does I miss somethings?
Thanks for yours anwsers
