Hi, i am using macOS Catalina 10.15.3 with an encrypted disk. The Cryptomator is version 1.4.17 (1451) and Fuse is 3.8.2. I could create a vault but could not unlock it.
The problems in the log start with that:
11:55:04.678 [Background Thread 2] DEBUG o.cryptomator.cryptofs.ReadonlyFlag - Vault opened for read and write.
11:55:05.286 [Background Thread 2] DEBUG org.cryptomator.ui.model.FuseVolume - Successfully created mount point: /Volumes/XffEeu-ITsdt_0
11:55:05.819 [JavaFX Application Thread] ERROR o.c.ui.controllers.UnlockController - Unlock failed for technical reasons.
org.cryptomator.ui.model.Volume$VolumeException: Unable to mount Filesystem
at org.cryptomator.ui.model.FuseVolume.mount(FuseVolume.java:108)
at org.cryptomator.ui.model.FuseVolume.mount(FuseVolume.java:58)
at org.cryptomator.ui.model.Vault.unlock(Vault.java:115)
Opening the same vault (it’s in Dropbox) from High Sierra works without problems.
Does anybody have some suggestion or a solution for me?
Best, Mike
