Creating and accessing vaults work fine. When trying to lock any vault, it fails. Also fails to force lock vault.
I have tried to create vaults “all over the place” in my Home directory, even in the same directory as the Cryptomator appimage. Same result. According to the system admin I have normal read/write permission to the /.local/share/mnt directory. I do not have any read/write permission to the local OS disk.
Any ideas?
12:32:55.322 [JavaFX Application Thread] TRACE o.c.u.controllers.UnlockedController - Regular unmount failed.
org.cryptomator.ui.model.Volume$VolumeException: org.cryptomator.frontend.fuse.mount.CommandFailedException: Command failed with exit code 1. Expected 0. Stderr: fusermount: failed to chdir to /home/.../.local/share/Cryptomator/mnt: Permission denied
at org.cryptomator.ui.model.FuseVolume.unmount(FuseVolume.java:142) at org.cryptomator.ui.model.Vault.lock(Vault.java:134)
atorg.cryptomator.ui.controllers.UnlockedController.lambda$regularLockVault$1(UnlockedController.java:116)
Caused by: org.cryptomator.frontend.fuse.mount.CommandFailedException:
The following exception is near identical with only difference Forced unmount failed
Sorry for weird formatting of error message.
