i have a problem with my Cryptomator Container.
–> I´m unable to delete or rename a Folder in it.
The sanitizer reports:
1 problem(s) found.
WARN MissingDirectory path: d\EX\QEHFP4CAWLFK5CZDGQ3VQVCCNDT26B dirfile: d\P4\QZPPLFOGVJURRZOGK2KAWQLMM3OI5A\0EIOXS44YCN26MGB3O64VVH76WCIA==== notADirectoryButExists: false
INFO RootExists d\P4\QZPPLFOGVJURRZOGK2KAWQLMM3OI5A
In the first run i had delete more that 1000 orphan Metadata files
Remove orphan metadata file m\W3\E3\W3E3LXCNSCUXIGGL3BJW6VKIGIKDEJMW.lng... [OK]
Remove orphan metadata file m\XQ\6O\XQ6OFRTABXWOSHAAJD3WXFE3RRO3DLIO.lng... [OK]
Remove orphan metadata file m\3G\SF\3GSFGGRDWWKHUP3LGTTZ2YYRZ4DKICQZ.lng... [OK]
Remove orphan metadata file m\HZ\MY\HZMYIQO5Z5IJAWJXVEPJH3PYBZN3RN4K.lng... [OK]
Remove orphan metadata file m\K5\CC\K5CCNXOVISBWS2XC4BBPXE65HIZZOB2N.lng... [OK]
Remove orphan metadata file m\3H\JU\3HJUYWBGUQMPRDILXC3UC74ZMOMOKTBT.lng... [OK]
Remove orphan metadata file m\CQ\BX\CQBXKJXVMPQLAFN5ZH634JFELGGX7DXE.lng... [OK]
Remove orphan metadata file m\TJ\UC\TJUC4I6DLDQJWA5YF3T3KUFU3R63DE7D.lng... [OK]
Remove orphan metadata file m\XU\GF\XUGFRW2MRXTDDA6LDTQLERCWWOIYOU7E.lng... [OK]
Remove orphan metadata file m\HB\RF\HBRFL7ZXFIB3YVAQ6RP2O3XJPQ7HUZGQ.lng... [OK]
But the Error with the “WARN MissingDirectory path” still exists.
I´m using Mountain Duck under Windows 10 1803. My Vault is in the OneDrive Cloud.
I´m running the latest Cryptomator, Mountain Duck, sanitizer Version.
Is there a way to fix this problem ? Do you need more logs or informations ?
Thanks for any help!
