Solved: org.cryptomator.common.vaults.Volume$VolumeException: Unable to mount Filesystem
I have 2 windows machines. Both attempt to open the same 2 vaults on Windows startup. Cryptomator crashes on both with the following error
	... 11 more
	... 13 more
If I quit Cryptomator and restart it both vaults open ok.
I am using Cryptomator v1.5.16 and
|Edition|Windows 10 Home|
|Version|21H1|
|Installed on|‎16/‎12/‎2020|
|OS build|19043.1052|
|Experience|Windows Feature Experience Pack 120.2212.2020.0|
Hi. Please see here: [1.5.15 / 1.5.16] Cannot mount vault: Mount Timed Out
Thanks for the quick reply.
I was already using the latest version of Cryptomator and Donkey but this option worked for me:
Solution 3: Increase threshold manually
