I`m new to the wonderfull world of Cryptomator.
So far really impressed with the software.
Never the less I got some speed issues:
I got an Odroid N2 connected to a Seagate Backup plus
It`s connceted via Ethernet cable to the Router
Router via ethernet cable to my windows PC.
When using the dokany protokoll i got some real S l o w d o w n s. . .
the transferrerate drops under 100kbps.
So i started to run some Benchmarks to see what could be the souce of the trouble
here are some results:
All Benchmarks measured in MBps:
I tested the R/W for the HDD itself using the dd command:
Odroid: 189 / 145
PC: 180 / 180 -
then i tested R/W for the samba LAN connection (using LAN Speed Test - Totusoft):
PC to Odroid: 106 / 9 -
now i started to benchmark the Cryptomator protokolls:
dokany: 73/9
webdav: 408/298
since i need to move bigger data then 4GB webdav is no option. I will try to install a real Gbit switch, not the provider modem for testing purposes.
but still i dont really get the 100KBps slowdowns. any idea what also can creat the imense decreses?
ty for your help
kind regards Fabian
