I checked the official AppImage documentation, and it specifically addresses where configuration files should be stored.
According to the documentation:
Normally the application contained inside an AppImage will store its configuration files wherever it always stores them (most frequently somewhere inside $HOME).
In other words, AppImage does not require configuration files to be stored in the same directory as the AppImage executable.
There are two officially documented approaches.
1. Normal configuration storage (default)
Applications continue using their usual Linux locations:
| Directory | Typical contents |
| ~/.config/ | Application settings |
| ~/.local/share/ | Application data |
| ~/.cache/ | Cached information |
| ~/.appname/ | Application-specific settings |
This is the default behavior whether you launch an AppImage manually or through Gear Lever.
2. AppImage portable mode (officially supported)
The AppImage documentation describes a mechanism for keeping configuration files alongside the executable.
For example:
~/Applications/
MyApp.AppImage
MyApp.AppImage.home/
MyApp.AppImage.config/
The two special directories have different purposes:
These are recognized automatically by compatible AppImage runtimes. You don’t need both directories; choose based on what you want to redirect.
What does the AppImage project recommend?
The documentation treats normal application-specific configuration storage as the default and portable mode as an optional feature, particularly useful when carrying applications between computers.
It also recommends ~/Applications/ as a good location for AppImage executables.
You can read the official documentation here:
AppImage — Using Portable Mode
My recommendation for Gear Lever: Keep using the normal Linux configuration locations unless you specifically want your AppImages to be portable. This also avoids potential problems when Gear Lever updates or renames AppImage files.
