Hi everyone. I am a new Cryptomator user and am evaluating the software to see if it suits my needs. I see from another post that unlocking and mounting can be done automatically but I cannot find anything in preferences to allow me to do that. Where would that option be located? I would also know if I can change the drive letter assigned to the unlocked and mounted folder. Thanks.
You can do that in the “Vault Options”: https://docs.cryptomator.org/en/latest/desktop/vault-management/#vault-options
Thank you. Found the setting and it works well. I would still like to know if the drive letter for the virtual drive can be changed. I need the drive letter to be higher and fixed if possible.
That should be possible. Check out the “Mounting” tab. I know, these are Mac screenshots in the aforementioned link but on Windows, there should be an option to choose a drive letter.
Once I found that I had to relock the vault to get to options it was easy. Thanks again! I think this is going to be the way to go for encrypting files across windows and android. Easier than Boxcryptor and less expensive!
