Sanitizer decryptVault Java Error "Unable to read header from channel"
In Bezug auf Leerer Ordner auf Cyberduck hab ich meine korrupte Vault einfach mal probiert mit Sanitizer zu decrypten. 70,3gb von 237gb konnte ich wiederherstellen, mittendrin ist der Prozess dann abgestürzt:
Failed to authenticate name of PF\WJFSVUGOFAKSETXVJAXKSN7FRECGWW\7MROXB2GX6NIFC3DN22GQTDHOIUPA5ZH.lng
PF\WJFSVUGOFAKSETXVJAXKSN7FRECGWW\7MROXB2GX6NIFC3DN22GQTDHOIUPA5ZH.lng -> H:\Decrypted\lost+found\root-5\unknown-folder\XXXXXX\XXXXXX\unknown-file.LNG (Pfad habe ich zensiert)
Exception in thread “main” java.lang.IllegalArgumentException: Unable to read header from channel.
at org.cryptomator.cryptolib.v1.DecryptingReadableByteChannel.loadHeaderIfNecessary(DecryptingReadableByteChannel.java:75)
at org.cryptomator.cryptolib.v1.DecryptingReadableByteChannel.read(DecryptingReadableByteChannel.java:48)
at org.cryptomator.sanitizer.restorer.ScannedVault$EncryptedFile.tryDecryptTo(ScannedVault.java:310)
at org.cryptomator.sanitizer.restorer.ScannedVault$Entry.decryptTo(ScannedVault.java:355)
at org.cryptomator.sanitizer.restorer.ScannedVault$EncryptedDirectory.lambda$decryptContentsTo$1(ScannedVault.java:231)
at java.base/java.util.ArrayList.forEach(ArrayList.java:1507)
at org.cryptomator.sanitizer.restorer.ScannedVault$EncryptedDirectory.decryptContentsTo(ScannedVault.java:231)
at org.cryptomator.sanitizer.restorer.ScannedVault$EncryptedDirectory.tryDecryptTo(ScannedVault.java:214)
at org.cryptomator.sanitizer.restorer.ScannedVault.lambda$decryptTo$0(ScannedVault.java:194)
at java.base/java.util.stream.ForEachOps$ForEachOp$OfRef.accept(ForEachOps.java:183)
at java.base/java.util.stream.ReferencePipeline$3$1.accept(ReferencePipeline.java:195)
at java.base/java.util.HashMap$ValueSpliterator.forEachRemaining(HashMap.java:1677)
at java.base/java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:484)
at java.base/java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:474)
at java.base/java.util.stream.ForEachOps$ForEachOp.evaluateSequential(ForEachOps.java:150)
at java.base/java.util.stream.ForEachOps$ForEachOp$OfRef.evaluateSequential(ForEachOps.java:173)
at java.base/java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234)
at java.base/java.util.stream.ReferencePipeline.forEach(ReferencePipeline.java:497)
at org.cryptomator.sanitizer.restorer.ScannedVault.decryptTo(ScannedVault.java:194)
at org.cryptomator.sanitizer.restorer.VaultDecryptor.run(VaultDecryptor.java:41)
at org.cryptomator.sanitizer.commands.DecryptVaultRunner.run(DecryptVaultRunner.java:21)
at org.cryptomator.sanitizer.commands.DecryptVaultCommand.run(DecryptVaultCommand.java:91)
at org.cryptomator.sanitizer.commands.Commands.run(Commands.java:75)
at org.cryptomator.sanitizer.Sanitizer.main(Sanitizer.java:16)
at java.base/java.util.Optional.ifPresent(Optional.java:176)
at org.cryptomator.sanitizer.Sanitizer.main(Sanitizer.java:12)
Soll ich dann wie bei https://github.com/cryptomator/sanitizer/issues/7 alle .lng files unter 88 Bytes löschen? Das wären 6 Dateien
Edit: Die 6 .lng Dateien habe ich gelöscht und Sanitizer neu laufen lassen. Konnte deutlich mehr wiederherstellen, der Prozess bricht aber irgendwann wieder ab
