I have an instance of cryptomater running on my Samsung phone. I have installed another instance of cryptomater in the Samsung secured folder but I can’t figure out how to get it to connect to the container I created in n the other instance. Can someone help me?
I’m also on Samsung so I will try and reproduce your scenario.
My first thought is that it’s functioning as designed. let me check. Secure apps should be secure.
Ok, I added cryptomator software to my secure folder. When I open the app it is as if it’s a new install and none of my vaults that are in the app on the main homepage of my phone are there but I was able to authenticate to Google Drive and add them in.
I thought I could do that also, but I guess I don’t know where to look for the cryptomater file.
Oh. I found it.
Thanks for your help.
Glad I could help somebody today.
