Is manually reopening a vault after a reboot always required or have I missed something when initially setting up my vault? I’m not sure what the purpose would be of forcing this after every reboot would be.
If you want to Auto Unlock your vault on cryptomator startup, you can configure this in the vault options. If you do not want to type in your password, then you have to save the password in Cryptomator.
Michael, thanks for responding to my query. I had saved the password but after a reboot I would be prompted to manually UNlock the vault. I couldn’t find any option in Settings to automaticaly unlock at restart. THEN I realized that option doesn’t appear in Settings, it was under Vault Options (perfectly logical) and now all is well.
